Go to Post Competing at multiple regionals or Championship events has no bearing on the life lessons you will learn or the unbelievable memories you will have--for that is what FIRST is truly all about. - Alivia [more]
Unread 24-01-2014, 20:58
LFRobotics's Avatar
LFRobotics LFRobotics is offline
FRC #4623
LFRobotics is on a distinguished road
VZ-2B17D8-048 Limit Switch Wiring
Hey robot peeps - Im the head electronics/programming guy on the LF Robotics team - I am the only one of my kind on the team and this is my first year - so I have absolutely NO experience.
So......
I want to have a winMotor spin a wheel until it reaches the end of a cord and hits a limit switch - when it hits that limit switch I want it to reverse its direction until it hits a second limit switch which will be located at the point that it started from - when it hits this limit switch I want it to stop until it is triggered to start again by a button on the joystick.
How do I wire the limit switches? I seriously have absolutely no idea how to wire them or how to program them. The programming questions will be posted in the programming section. The switches have three pins - NC2, NO3, and COM1(Normally Closed, Normally Open, Common Ground).
Here is a picture of the switch:
I am using Java with Netbeans.
Any help will be GREATLY appreciated - THANKS!
Unread 24-01-2014, 21:16
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Re: VZ-2B17D8-048 Limit Switch Wiring
So......
Either the Normally Open (NO3) or Normally Closed (NC2) should be connected the white wire of a PWM cable. The Common Ground should be wired to the black wire of the PWM cable. Nothing should be connected to the red wire. The Female end of the PWM cable should be connected to one of the digital inputs on the Digital Sidecar.
Unread 25-01-2014, 00:46
vps vps is offline
FRC #3021 (The Agency)
vps is an unknown quantity at this point
When in doubt, use a multimeter. At the end of the day, it's just a switch.
Unread 25-01-2014, 12:05
LFRobotics's Avatar
FRC #4623
Okay - THANKS a ton guys!
