Go to Post My sister's husband told me when I was just a wee one, "momentum will take you where traction will not." - Joe Johnson [more]
Unread 25-01-2014, 13:25
RunAdamRun RunAdamRun is offline
FRC #5145
RunAdamRun is an unknown quantity at this point
Bumper Question
Our team 5145, a rookie team, has a bumper question. We received the AM14U drive-train kit and we are unsure if it is okay for our bumpers to come over the sides of our drive-train because they need to be 5 inches tall and our drive train is only 3 3/4 inches. So can the wood of the bumpers be wider than the frame's height. Also, the AM14U has a gap between the center frame and the outer frame that holds the wheels together. Is it okay that we do not have the wheel gap covered when the frame goes on because in the rules it says in R26 B. "the gap between the backing material and the frame must not be greater than 1/4in." So does the wheel gap not count as being backed? Any other tips on bumpers would also be appreciated.
Unread 25-01-2014, 14:02
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
Re: Bumper Question
Yes it is fine to have your bumpers extend over or hang below your frame as long as they are within the window of 2-10" from the floor. (R22)
The gap where the wheels are would have to be covered with bumpers because they are within 8" of a corner. (R26)
Basically use the corner of the robot as you frame perimeter. The inner frame doesn't count as your actual frame perimeter. The extensions where the wheels are housed is a part of your frame.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 25-01-2014, 14:30
FRC #5145
Re: Bumper Question
Thank you for the feedback. We do plan to cover the gap at the corners with the bumper, but the question is, do we need to have a metal backing behind the bumper where the gaps are?
Unread 25-01-2014, 14:36
Re: Bumper Question
No, the plywood will do just fine. However, you can put one in if you wish to.
Andrew Basse
Unread 25-01-2014, 14:43
EricH EricH is online now
Re: Bumper Question
Just to clarify slightly: The plywood is a required part of the bumper. However, aluminum angle is allowed per the bumper rules (not required); other stiffeners/backings would probably need to be part of the attachment system in order to be used.
Unread 25-01-2014, 20:33
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Bumper Question
You are allowed to have 'gaps' deeper than 1/4" in the supporting frame, as long as they are less than 8" long.
Remember the bumpers have to be supported at the ends (i.e., corners)...
Unread 26-01-2014, 00:14
Re: Bumper Question
Guys,
I think the OP is asking about the gap in the frame at the front and back of the robot. I suspect that the flange of the outer plate when used with the AM bumper kit satisfies the 1/2" rule for robot structure. This looks like a Q&A.
Unread 26-01-2014, 09:09
Re: Bumper Question
Guys,
That's how I answered it, I don't think it makes much sense that FIRST would offer the kit robot with modifications necessary to make it legal to play. I agree that the flange on the outer plate having vertical mounting is to satisfy the 1/2" from the edge mounting.
Andrew Basse
