Go to Post I suggest that you don't discuss...sensitive issues about your team on this public forum. - Andy Baker [more]
Unread 25-01-2014, 13:25
5339 5339 is offline
FRC #5914
Rookie Year: 2104
5339 is an unknown quantity at this point
Logitech extreme 3d pro
How to program the throttle on the 3d pro? What are the inputs? We r programing in Java.
Unread 25-01-2014, 13:34
PikaDotus's Avatar
PikaDotus PikaDotus is offline
CEO
FRC #3501
PikaDotus is an unknown quantity at this point
Re: Logitech extreme 3d pro
On this joystick, the x-axis (left-right) is axis 1; the y-axis (up-down) is axis 2; the z-axis (twist) is axis 3; the throttle (on the bottom of the base of the stick) is axis 4.
To access these axes in Java:
Joystick joystick = new Joystick(1);
joystick.getRawAxis(4);
// etc.
You can also use the joystick methods that don't use the raw axes, however I like using the raw ones.
Technical debt is investing in the present using the future as collateral.
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
Just program it the same way you program other axes. The axes are as follows:
Axis 1: x
Axis 2: y
Axis 3: z (Twist)
Axis 4: Throttle
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
Unread 25-01-2014, 13:56
FRC #5914
Rookie Year: 2104
We are trying to set the speed for our robot using the throttle. Can you help us with that?
Unread 25-01-2014, 14:18
Happy Birthday! EricH EricH is offline
Speaking from experience: Why?
Most folks around here just use the Y-axis to control speed; if you're in single-stick drive, X generally becomes your turning control. (For 2-stick drive, AKA "tank", each Y-axis controls one side of the drivetrain.) Using the throttle to control speed just seems like you're overly complicating things.
Unread 27-01-2014, 19:59
FRC #5914
Rookie Year: 2104
Thanks for you reply. Our robot moves erratic and hard to control that is why we are trying to use the throttle to slow it down at times to gain better control but we have been unsuccessful att.
