Go to Post [You know you've overdosed on FIRST when...] When you discover that the cure to the swine flu is "oink oink BOOM!" - Katie_UPS [more]
Unread 25-01-2014, 13:53
Walter Deitzler's Avatar
Walter Deitzler Walter Deitzler is offline
UAH Class of 2019
FRC #3397 (Robolions)
Walter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond repute
AM Battery Tray Problem
So, we opened up the AM battery trey that is sold in addition to the AM14U and, after mounting to our AM14U, we discovered a pretty big problem, the battery does not fit.
Anybody else seem to be having this problem?
Thanks.
(Hanging out with my buddies at 610)
Robotics, it's not just a club, it's a career.
FLL Referee (2012-Present)
2014 Gateway Robotics Challenge winners (With 2481 and 1985)
2011 St. Louis Regional Winners (With 1985 and 3284)
2010 Highest Rookie Seed
I am the guy in the golden hat, say "Hi!" to me at WORLD CHAMPIONSHIPS!!!
Unread 25-01-2014, 18:51
Sparky3D's Avatar
Sparky3D Sparky3D is offline
AKA: Dustin D
FRC #1736 (Robot Casserole)
Sparky3D is a glorious beacon of lightSparky3D is a glorious beacon of lightSparky3D is a glorious beacon of lightSparky3D is a glorious beacon of lightSparky3D is a glorious beacon of light
Re: AM Battery Tray Problem
We had the same problem when we installed it the first time. The holes on the chassis seemed like they were a little too close together for the battery to fit properly. We ended up cutting a piece of wood the width of the battery, jamming it in the tray to spread it out a bit, and then drilling new holes in the chassis for it. Now it fits fine.
Unread 25-01-2014, 19:09
magnets's Avatar
magnets magnets is offline
the size of the batteries is not consistent between batteries, and can even bloat out sometimes. We've gotten a battery stuck in a wooden battery box once, and we could take it out with a rubber mallet. We had to take apart the robot. If you're building a battery box, make sure that whatever holds it on the side is adjustable, and that it's held down with some sort of strap, or something that can be ok with slight variations in height.
Unread 25-01-2014, 20:06
DonRotolo's Avatar
Back to humble
FRC #0832
We use 1/2" thick high-density closed-cell foam to surround the battery. Not only does it allow for size variation, it helps dampen vibration (batteries hate vibration).
Unread 25-01-2014, 20:08
zeldathegood zeldathegood is offline
FRC #4277
zeldathegood is an unknown quantity at this point
Yes, we are having the same problem. we have 4 batteries, 1 doesn't fit at all, 1 fits but will not come back out and the 2 others work like a dream. I think we will try the 'jamming the wood' trick. Can they post a picture?
Unread 25-01-2014, 20:11
UAH Class of 2019
This year we decided to go with the AM battery tray because of its design to mount to our KOP frame. So, that is what we are syciking with. We eventually got ours to fit by loosening the bolts just enough to have the battery bend the aluminum out, so now it works.
Unread 26-01-2014, 00:26
What sides of the battery is it sticking on? The short sides or the long sides?
Unread 26-01-2014, 19:14
FRC #4277
We are sticking due to the length of the batteries.
Unread 26-01-2014, 19:20
rwkling1's Avatar
rwkling1 rwkling1 is offline
FRC #2977 (Sir Lancer Bots)
rwkling1 has a spectacular aura aboutrwkling1 has a spectacular aura about
Yes, this happened to us also. We just made the holes a little bit larger and spread out the bracket while we tightened it, now it's fine.
Unread 26-01-2014, 21:03
Liz Smith's Avatar
Liz Smith Liz Smith is offline
believes in robots
AKA: Pika1579
FRC #3940
Liz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond repute
Send a message via AIM to Liz Smith
There is some variation in the sizes of the batteries and the bends on the AM14U battery bracket. Here are some tips in getting the batteries fit in the bracket while still remaining snug.
1. Open up the 0.2" diameter mounting holes, both on the bracket and the AM14U Cross Brace. Make them a new diameter of 0.25".
2. Put the battery in the bracket while the screws are not yet tight. Also, put a 1/16" thick wedge or slip of plastic between the battery and the face of the aluminum bracket. Wedging this shim between the aluminum and battery will be difficult, but it will help with setting up the fit.
3. With the plastic wedge or shim in place, tighten the mounting screws for the bracket.
4. Pull out the plastic wedge or shim.
We are using this bracket on the our robot for 3940 and have used this method to get our batteries to fit nicely.
Alumna of 555 Mentor of 3940
Volunteering since 2004: Say hi to me at events!
Applications Engineer
AndyMark, Inc.
