Go to Post I believe that "going home a winner" is more a matter of perception than anything else. - JesseK [more]
Unread 25-01-2014, 14:11
Dr. Poptart's Avatar
Dr. Poptart Dr. Poptart is offline
AKA: Ysidro Perez
FRC #1817 (LLano Estacado RoboRaiders)
Dr. Poptart is an unknown quantity at this point
Robot not driving and programmer is unavailable
Team 3345 mentor here.
We're in a bit of a bind. We've managed to put together our drivetrain, using two motors per side, and tried to image the cRIO with our program from last year (time-constricted programmer). Whenever we try to drive, it seems like the gearbox motors fight against each other, but we're not sure at this point if the problem is that or if we've got an issue with the motor controllers. As I've said earlier, our programmer is a bit busy at the moment and can't seem to find the time to debug or even rewrite the program. We've tried switching motor inputs on the sidecar to match those from last year's robot (which the code we're using was made for).
We've tried asking him to just rewrite the code, but that doesn't seem to get through to him.
The two motors on the left side of the drivetrain are connected to sidecar ports 2 and 4, whereas the two on the right are connected to ports 1 and 3.
I don't have the code to put up at this moment but as soon as I can get it I'll edit this and put it up for you guys. As for now, I just want to know if any programmer in the area of my school (3200 McCullough Avenue, San Antonio, Texas, 78201) can perhaps come over and teach some of our more available members to program in any language (we're using Java at the moment, but any language is fine), we would really appreciate it.
Unread 25-01-2014, 14:14
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
Re: Robot not driving and programmer is unavailable
I would use a PWM splitter from the KOP to connect he motors from each side to the same output on the DSC to make sure that both motors from each side are turning the same way at the same speed at the same time. Otherwise, there is a very serious danger of something breaking. Also, you don't have to adjust the code for it!
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
Unread 25-01-2014, 16:54
AKA: Ysidro Perez
Originally Posted by Whippet View Post
I would use a PWM splitter from the KOP to connect he motors from each side to the same output on the DSC...
Thanks, I was thinking of doing this from the start but I just got around to it. That solved our movement problem, but now we've got another two problems on our hands. The first one we can fix - when we move forward, one side moves forward while the other moves backwards. This behavior persists through all movements as expected. We can solve that.
But we're also getting some issues with just driving. The left set of wheels will only move at very low speeds and behavior is unpredictable; sometimes it behaves as explained, and sometimes it just won't move at all. The right side can handle a bit more speed, but when I push our control joystick all the way forward the wheels stop and there is a stripping sort of sound in the gearbox. An outside mentor has suggested that perhaps one or more of the gearbox motors' keys may have slipped off. We're looking into the issue now. Does anyone else have any other ideas?
Unread 25-01-2014, 18:22
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
This is actually an expected behavior on most drive trains. You need to reverse one side in code. Like you said it's a very easy fix.
Make sure both motors in each gearbox are being powered. The easiest way to do this it to check the temperature of both motors after a long period of driving.
NotInControl NotInControl is offline
Controls Engineer
AKA: Kevin
FRC #2168 (Aluminum Falcons)
NotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond repute
Since you have two motors per side you need to make sure that both motor controllers are driving the wheels in the same direction so that the motors are not fighting each other.
There are many ways to do this, one of the simplest ways is remove all the drivetrain motor controller breakers from the power distribution board.
Then plug in only one breaker, turn the robot on, and spin that side of the drive train with the joystick controls, and note which direction the wheel spins. Turn the bot off, Remove that breaker and plug in the breaker for the other motor controller for the same side of the drive train. Turn the robot back on, and drive the wheel again, noting the direction the wheel spins.
Repeat this for the other side as well. If you have a single side, where the wheel spins in opposite directions, then your motors are fighting each other, and you need to correct it.
If this is the case, and you do not have the option to fix it in code, you can safely invert the wires on the MOTOR side of the motor controller, to get the motor spinning in the correct orientation.
Note: Make sure you only invert the M side of the motor controller, because inverting the power side, will fry the motor controller.
Hope this helps,
Kevin
Controls Engineer, Team 2168 - The Aluminum Falcons
[2016 Season] - World Championship Controls Award, District Controls Award, 3rd BlueBanner
-World Championship- #45 seed in Quals, World Championship Innovation in Controls Award - Curie
-NE Championship- #26 seed in Quals, winner(195,125,2168)
[2015 Season] - NE Championship Controls Award, 2nd Blue Banner
-NE Championship- #26 seed in Quals, NE Championship Innovation in Controls Award
-MA District Event- #17 seed in Quals, Winner(2168,3718,3146)
[2014 Season] - NE Championship Controls Award & Semi-finalists, District Controls Award, Creativity Award, & Finalists
-NE Championship- #36 seed in Quals, SemiFinalist(228,2168,3525), NE Championship Innovation in Controls Award
-RI District Event- #7 seed in Quals, Finalist(1519,2168,5163), Innovation in Controls Award
-Groton District Event- #9 seed in Quals, QuarterFinalist(2168, 125, 5112), Creativity Award
[2013 Season] - WPI Regional Winner - 1st Blue Banner
Unread 29-01-2014, 21:46
AKA: Ysidro Perez
SOLVED
Thank you, everybody. Your help is much appreciated!
Unread 29-01-2014, 22:02
Pratik Kunapuli's Avatar
Pratik Kunapuli Pratik Kunapuli is offline
Probably browning-out on Astro-Turf
FRC #1648 (G3 Robotics)(EWCP)
Pratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to all
Just a reminder that the speed controllers also need to be calibrated for the best performance.
Official Driving Record: 101-59-0
2012-2015 Student 341 Miss Daisy
2015-Current Mentor 1648 G3 Robotics
