Go to Post Joining a FIRST team is the beginning of "smart," not the culmination. - klrswift [more]
Unread 25-01-2014, 15:08
jdh042397's Avatar
jdh042397 jdh042397 is offline
Being a nerd really pays off!!
FRC #4063 (TRikzR4kiDz)
Team Role: Electrical
jdh042397 is an unknown quantity at this point
Micro Switch Limit?
Can we hard wire the limit switch in our design or does it need to go through a PWM?
2014 Hub City Regional Engineering Inspiration
2012,2013,2014 Alamo Regional Gracious Professionalism
2014 Dallas Regional Gracious Professionalism
2013 Alamo Regional Winners (2468 & 2789)
2013, 2014 Hub City Regional Finalist
"Robotics are beginning to cross that line from absolutely primitive motion to motion that resembles animal or human behavior."
J. J. Abrams
Unread 25-01-2014, 15:19
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
theawesome1730 will become famous soon enough
Re: Micro Switch Limit?
I believe the limit switch must be through PWM since the current motor controllers push to motors would burn the switch out. You may be able to find switched rated for a significant amount of amps but you probably won't pass inspection unless you route through PWM
2015 GKC Engineering Inspiration
2015 Colorado Winners
Unread 25-01-2014, 15:20
EricH EricH is online now
I suggest that you take a pretty good look at R71. Limit switches are considered to be custom circuits.
If by "hard wire" you mean running power through it, and using it to turn power on and off when tripped and not tripped, I would say that technically that's impractical.
Unread 25-01-2014, 15:40
Jay1986's Avatar
Jay1986 Jay1986 is offline
Programmer and Driver
AKA: Jay Urban
FRC #1986 (Team Titanium)
Jay1986 is a jewel in the roughJay1986 is a jewel in the roughJay1986 is a jewel in the roughJay1986 is a jewel in the rough
I would recommend wiring the limit switches to the DIO on the sidecar and program the function that you desire.
2013 Oklahoma Regional (Regional Winner, Gracious Professionalism, [and judges voted me star of the day])
2013 KC Regional (Regional Winner, Woodie Flowers, Industrial Design)
2013 Hub City Regional (Regional Winner, Entrepreneurship, Quality, Dean's List)
Unread 25-01-2014, 19:33
brycen66 brycen66 is offline
FRC #1678 (Citrus Circuits)
brycen66 is just really nicebrycen66 is just really nicebrycen66 is just really nicebrycen66 is just really nice
PWM is out put only. It is also illegal to wire it in series with a motor. The two legal implementations include using either the DIO or the Analog breakout, I would recommend DIO.
Unread 25-01-2014, 20:01
DonRotolo's Avatar
Back to humble
FRC #0832
The rules say that you MUST use the cRio to control anything. So a switch to supply & remove power to (something) is not allowed.
Use a Digital I/O on the Digital Sidecar to signal the cRio that the switch is tripped, and then use (somehting, maybe a PWM or a Relay) to make whatever it is, happen.
Unread 25-01-2014, 23:38
jdh,
I hope what you have gathered from the above posts is that only approved motor controllers (Victors, Jaguars, Talons, or Spikes) may be used to control motors. If you are using Jaguars, you may wire limit switches to the limit inputs on the Jaguar. Most people (as above) will recommend you wire a limit switch to a DIO on the digital sidecar and have it implement in software. This allows you to also pass the switch state to your driver's station if you want. It is also recommended that an electrical limit be backed up with a mechanical stop if the parts that move should be capable of exceeding the perimeter limit of the Frame + 20 inches.
