Re: Using CIMs at 30 amps?
I would suggest rethinking the type and number of motors that you need for each application.
Now, to answer your specific question:
You can put any of those motors on a breaker up to 40 amps. Anything lower than that is acceptable. This means you can put a 30 amp breaker on a CIM motor. You may have a problem with tripping the breaker though.
Based on R46 in the manual.
"A mind once stretched by a thought will never regain it's original dimensions."
Optimists think the glass is half full.
Pessimists think the glass is half empty.
Engineers realize it's twice as big as it needs to be.
