Go to Post Yes there are a lot of problems that will pop up solving the problem, but thats the reason we do engineering for. - Arefin Bari [more]
Unread 25-01-2014, 16:54
Rynocorn's Avatar
Rynocorn Rynocorn is offline
Strategist and Designer
AKA: Ryan Jacobs
FRC #1466 (Webb Robotics)
Rynocorn is on a distinguished road
9 mm Wide Belts
Hi everyone, my team is working on our final drive train and we were wondering how strong the 9mm belts are compared to the 15 mm belts? How would we even go about calculating if we need the thicker belts or is it just knowlege that you should use the wider 15mm belts for drive train applications. I didn't see any calculation tools on the vex site and just wanted to try and figure it out. Thanks you guys!
My favorite parts: Surgical tubing, Grab catches, churro tubing, and waffle tread.
Unread 25-01-2014, 17:00
Andrew Lawrence
Posts: n/a
Re: 9 mm Wide Belts
We used 9mm wide on our drive in the offseason and it worked perfectly.
Unread 25-01-2014, 17:14
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Re: 9 mm Wide Belts
# motors? Gearbox reduction? Belt reduction? Pully teeth? Wheel size? How many matches?
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 25-01-2014, 17:18
Andrew Lawrence
Posts: n/a
Re: 9 mm Wide Belts
6 motors, 6.11 ratio, belts were at 1:1, 24 tooth, 4" wheels, 12 competition matches, about 5-6 practice matches, and 4-5 hours of standalone practice at our shop.
Unread 25-01-2014, 17:47
Rynocorn's Avatar
AKA: Ryan Jacobs
Re: 9 mm Wide Belts
Thank you! That really makes my cad a lot prettier so I'm glad that you had a good experience with them!
Unread 25-01-2014, 20:28
DonRotolo's Avatar
Back to humble
FRC #0832
Re: 9 mm Wide Belts
Go to the belt manufacturer site to get strength ratings.
Unread 25-01-2014, 21:12
Re: 9 mm Wide Belts
And when the belt manufacturers site says the belts are way undersized, realize that those ratings are based on working forever (rather then 100 hours) under continual torque loads and at much higher RPMs. Personally, I think the collective experience of the FRC community would be better then the manufacturers site.
Unread 25-01-2014, 21:54
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Re: 9 mm Wide Belts
My experience says to never use 9mm wide belts in the drivetrain. Sometimes they will work but sometimes they won't We have run belts the past 4 seasons and have gone back to chain for this season.
Mentor 2415
Unread 25-01-2014, 21:58
Mr. Van Mr. Van is offline
#0599 (Robo-Dox)
Mr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond repute
Re: 9 mm Wide Belts
Uh - this worries me. We're trying belts ourselves for the first time - 9mm. (2 CIM driving 6" AM high-grip wheels via a SuperShifters, WCD.) What were your failure points? Why did you go back to chain?
- Mr. Van
Coach, Robodox
Unread 25-01-2014, 22:05
AKA: Sean
Re: 9 mm Wide Belts
- Mr. Van
Coach, Robodox
What pullies are you running, specifically tooth count? 6" wheels complicates the matter even more, as the load in the belt is higher than with a smaller diameter wheel. Also will you have a means for tensioning or are you setting it up for exact center to center distance?
The failures we experienced were mostly ratcheting, teeth skipping as we changed direction rapidly. This of course accelerates wear and leads to failure quicker than normal. That said, we never had a belt totally fail, although we replaced belts every regional.
Mentor 2415
Unread 25-01-2014, 22:11
Qbot2640's Avatar
Qbot2640 Qbot2640 is offline
AKA: Terry McHugh
FRC #2640 (Hotbotz)
Qbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond repute
Re: 9 mm Wide Belts
From a straight-forward strength comparison, the different widths are the same material - just different width...so 9mm would theoretically have 9/15 the tensile strength of 15mm. Anecdotally, and just from my observation - it seems to me the biggest difference would be the amount of surface engagement between belt and pulley. The only problem we have had with belts is the situation where the required torque causes the belt to ratchet over the pulley. Less surface contact would lower the threshold. We have not observed this problem with a drive-train application, rather with other systems, trying to pivot exceptionally heavy mechanisms.
- Mr. Van
Coach, Robodox
We used 15mm belts on the drive train for the first time last year and loved it. It seems so much smoother, quieter, and lighter than a chain-driven system. Unless presented with some special circumstance, I can't see going back to chain.
2012 Palmetto Regional Winners (Thanks 2059, 2815, and 287).
2012 Newton 14th Seed
2013 Chesapeake Regional Imagery Award Winners
2014 North Carolina Regional Imagery Award Winners
2014 Greater DC Regional Team Spirit Award Winners
2015 North Carolina Regional Finalists (Thanks 3971 and 587)
Andrew Lawrence
Posts: n/a
Re: 9 mm Wide Belts
Sounds like your belts weren't correctly tensioned. Too much tension on a belt will strip the teeth.
Unread 25-01-2014, 22:15
AKA: Sean
Re: 9 mm Wide Belts
I didn't say the teeth stripped. I said the teeth ratcheted or skipped teeth during rapid direction changes.
Mentor 2415
Unread 25-01-2014, 22:17
Andrew Lawrence
Posts: n/a
Re: 9 mm Wide Belts
Then that could be not enough tension, or too small a pulley size. How many teeth did you use?
Unread 25-01-2014, 22:23
AKA: Sean
Re: 9 mm Wide Belts
Or the belts are outside of their safe working limit. They were 26 teeth, and slightly on the overtight side. In my experience, belts are not very well suited for rapid direction changes with relatively high torque and minimal tooth engagement which is what happens in a west coast drive since pullies are generally kept smaller than 2" diameter.
Mentor 2415
