Go to Post REMEMBER - there ARE things more important than robots... false - Botwoon [more]
Unread 25-01-2014, 15:02
vigneshv vigneshv is offline
FRC #2489
vigneshv is on a distinguished road
Exclamation PIDController not manipulating jaguars
Hi,
I have a PIDController with the PIDSource as an encoder and the PIDOutput as a Jaguar. Even though the PIDController->GetError() returns a value of 100 (the encoder distance value - setpoint (this is correct)), the Jaguars do not run automatically to minimize the error. Why is this happening?
Unread 25-01-2014, 16:30
Re: PIDController not manipulating jaguars
What values did you use for P, I, and D? Did you enable the PID Controller?
Unread 25-01-2014, 17:41
FRC #2489
P = 13, I = 13, D = 13, PID was enabled.
Unread 25-01-2014, 17:59
NotInControl NotInControl is offline
Controls Engineer
AKA: Kevin
FRC #2168 (Aluminum Falcons)
NotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond repute
Are there any flashing or solid lights on the Jaguar? is it a black jag or a grey one? Do you notice the same behavior using BDC-COM?
Controls Engineer, Team 2168 - The Aluminum Falcons
[2016 Season] - World Championship Controls Award, District Controls Award, 3rd BlueBanner
-World Championship- #45 seed in Quals, World Championship Innovation in Controls Award - Curie
-NE Championship- #26 seed in Quals, winner(195,125,2168)
[2015 Season] - NE Championship Controls Award, 2nd Blue Banner
-NE Championship- #26 seed in Quals, NE Championship Innovation in Controls Award
-MA District Event- #17 seed in Quals, Winner(2168,3718,3146)
[2014 Season] - NE Championship Controls Award & Semi-finalists, District Controls Award, Creativity Award, & Finalists
-NE Championship- #36 seed in Quals, SemiFinalist(228,2168,3525), NE Championship Innovation in Controls Award
-RI District Event- #7 seed in Quals, Finalist(1519,2168,5163), Innovation in Controls Award
-Groton District Event- #9 seed in Quals, QuarterFinalist(2168, 125, 5112), Creativity Award
[2013 Season] - WPI Regional Winner - 1st Blue Banner
Unread 25-01-2014, 18:52
FRC #2489
The Jaguar is a grey Jaguar, and the Jaguar just has a solid orange light. I cannot use Set() to manipulate it either.
Unread 25-01-2014, 19:12
gpetilli gpetilli is offline
FRC #1559
gpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to all
Are you using CAN or PWM for the Jaguar. If CAN, the gray Jaguars do not have an RS232 to CAN interface and can not be the first Jaguar in a chain. You should check it by using PC with BDC-COM and a serial cable to a black Jaguar and daisy chain CAN to the gray one. You might as well flash the firmware while you have it hooked up.
Unread 25-01-2014, 19:40
Controls Engineer
AKA: Kevin
Can you paste your code? Because the light is solid that means that the jaguar is correctly gettting power and receiving comms. It may be a programming problem, maybe the wrong motor controller is referenced.
Posting your code will help us better help you.
Unread 25-01-2014, 19:59
FRC #2489
We also get a PID output with a value between 1 and -1, but the Jaguar does not move. The Jaguar is connected to the PWM output port 1.
#include "WPILib.h"
class RobotDemo : public SimpleRobot
	RobotDrive myRobot; // robot drive system
	Joystick *stick; // only joystick
	DriverStationLCD *screen;
	Encoder *encoder1;
	Jaguar *motor1;
	PIDController *PIDmotor1;
public:
	RobotDemo():
		myRobot(1, 2)//,	// these must be initialized in the same order
		stick = new Joystick(1);
		screen = DriverStationLCD::GetInstance();
		encoder1 = new Encoder(13,14);
		motor1 = new Jaguar(1);
		PIDmotor1 = new PIDController(0.5,0,0,encoder1,motor1);
		PIDmotor1->SetContinuous(true);
		PIDmotor1->SetOutputRange(-1,1);
		PIDmotor1->SetTolerance(3);
		myRobot.SetExpiration(0.1);
	 * Drive left & right motors for 2 seconds then stop
	void Autonomous()
		myRobot.SetSafetyEnabled(false);
		myRobot.Drive(-0.5, 0.0); 	// drive forwards half speed
		Wait(2.0); 				//    for 2 seconds
		myRobot.Drive(0.0, 0.0); 	// stop robot
	void OperatorControl()
		myRobot.SetSafetyEnabled(true);
		encoder1->Start();
		PIDmotor1->SetSetpoint(0);
		while (IsOperatorControl())
			if(stick->GetRawButton(3))
				PIDmotor1->SetSetpoint(100);
			if(stick->GetRawButton(2))
				PIDmotor1->SetSetpoint(-100);
			if(stick->GetRawButton(4))
				PIDmotor1->Enable();
			screen->PrintfLine(DriverStationLCD::kUser_Line1, "Count = %d", encoder1->GetRaw());
			screen->PrintfLine(DriverStationLCD::kUser_Line2, "Error = %f", PIDmotor1->GetError());
			screen->PrintfLine(DriverStationLCD::kUser_Line3, "Setpoint = %f", PIDmotor1->GetSetpoint());
			screen->PrintfLine(DriverStationLCD::kUser_Line4, "Output = %f", PIDmotor1->Get());
			//myRobot.ArcadeDrive(stick); // drive with arcade style (use right stick)
			screen->UpdateLCD();
			Wait(0.005);				// wait for a motor update time
	 * Runs during test mode
	void Test() {
START_ROBOT_CLASS(RobotDemo);
Unread 25-01-2014, 20:09
Both the Jaguar and the RobotDrive are using PWM 1.
Unread 25-01-2014, 20:35
FRC #2489
So if we remove the RobotDrive, it will work?
Unread 25-01-2014, 20:36
FRC #2489
So if we remove the RobotDrive, it will work, because as I understand RobotDrive uses the Jag ports as well?
Unread 26-01-2014, 13:08
Put your PID-controlled Jaguar on a PWM port that isn't already being used by other code. It's a one-character change to your code, and a single connector to move from one set of pins to another.
motor1 = new Jaguar(3);
Unread 26-01-2014, 15:32
FRC #2489
Isn't the RobotDrive supposed to use the jaguar ports, or should I remove that entirely and control the robot with motor1->Set()?
Unread 26-01-2014, 21:38
The questions you're asking seem to be assuming something that you haven't told us. Can you explain exactly what you're trying to get the robot to do? What sort of mechanism are you controlling, and where do you have the encoder mouted? I get the feeling that what you want is something you haven't quite made clear to us.
Unread 27-01-2014, 09:14
FRC #2489
Hi,
I am trying to use the PID controller to keep the robot stationary while shooting.
