Go to Post The GDC giveth, the GDC taketh away. Blessed be the name of the GDC. - GaryVoshol [more]
Unread 25-01-2014, 17:15
m616m's Avatar
m616m m616m is offline
FRC #2240
m616m is an unknown quantity at this point
Poly-cord Troubles
Does anyone know how to string poly-cord around pulleys without disrupting the pulleys?
Unread 25-01-2014, 18:35
TheKeeg's Avatar
TheKeeg TheKeeg is offline
Michigan Tech Engineering
AKA: Keegan Harrington
FRC #0068 (Truck Town Thunder)
TheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud of
Re: Poly-cord Troubles
I would like to help but I don't really know what you mean by disrupting the pulley?
Unread 25-01-2014, 18:42
Phyrxes's Avatar
Phyrxes Phyrxes is offline
Has done the math, have you?
AKA: Dave Button
no team (No Team, Changed Schools)
Phyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant future
A couple things:
1. Do you have a picture or video and like the previous poster asked what behavior are you seeing?
2. Is it solid core fused together polycord or the hollow variety with barbs?
3. Is the pulley smaller than the suggested radius for the material, this is probably a yes but given our run times it usually isn't a huge issue.
Dave Button
Physics and Mathematics Teacher
Wakefield School
The Plains, VA
“Simplify and add lightness.”
― Colin Chapman, Team Lotus
Unread 25-01-2014, 20:18
DonRotolo's Avatar
Back to humble
FRC #0832
To melt polycord ends while installed, we made a fixture to hold the cord while we melted the ends.
Basically, a piece of wood with 2 clamps on it. Clamp one end, pull real hard and clamp the other end, then join the ends. Urethane polycord does stretch a little bit...
Unread 25-01-2014, 20:30
jimwick's Avatar
jimwick jimwick is offline
jim wick
FRC #0885 (the Green Team)
jimwick is a glorious beacon of lightjimwick is a glorious beacon of lightjimwick is a glorious beacon of lightjimwick is a glorious beacon of lightjimwick is a glorious beacon of light
It sure is a lot easier to make the belts before you try to put them on the machine. Weld the ends together, then install them.
