Go to Post The toughest regional that matters is the one you're in! - pfreivald [more]
Unread 25-01-2014, 16:21
William Kunkel William Kunkel is offline
Programming Lead
AKA: Kunkel
FRC #0422 (Mech Tech Dragons)
William Kunkel is an unknown quantity at this point
Using the TableViewer Application
FIRST provides an application called TableViewer to look at and modify Network Table values on the fly, which they describe here: http://wpilib.screenstepslive.com/s/...rktable-values However, the application that I have looks nothing like the one on ScreenStepsLive, and when I tell it to connect as a client to my robot, it just says, "Disconnected". Do I have the wrong version, or is the documentation out of date? How can I make mine connect to my robot?
Unread 25-01-2014, 18:58
Re: Using the TableViewer Application
I agree that the TableViewer look has changed significantly. I didn't have any trouble getting it to connect to the robot as a client. Did you give it the Robot's IP address?
The OutlineViewer is very similar. Have you tried it?
Unread 25-01-2014, 19:26
Programming Lead
AKA: Kunkel
I did give it the robot's IP address. What is outlineviewer? I saw it in the folder but didn't know what it was for. Maye I should check it out.
Unread 25-01-2014, 19:43
It's a slightly fancier version of TableViewer.
