| My love spiders out in a web of emotions when I think of you. |
| Thread Tools |
Rating:
Display Modes |
#31
Re: 95 Hard at work
The hypertherm looks way better than the miller we have. Are miller broke down so we are hopefully getting a hypertherm to replace it. The miller took days of tuning to do mediocre cuts.
#32
Re: 95 Hard at work
Re: 95 Hard at work
Putting my CNC router to work making the 'deck' for our robot.
Setup details: 4'x4' Torchmate Small Shop Machine router table, 100IPM X,Y travel, 10IPM plunge, 1/16in DOC, 1/8in OD 2-flute down-cut carbide router bit, 24,000rpm spindle speed. This whole setup is considerably less expensive than a plasma cutter table, and can do more materials to a better tolerance, but at a much slower rate. All of this cutting was about an hour's worth of time, not including programming or setup. ![]() http://www.youtube.com/watch?v=0K8_R...ature=youtu.be Apologies for the cell-phone picture and video, best I had at the time! Last edited by JamesCH95 : 23-01-2014 at 11:40. |
#34
Re: 95 Hard at work
That point during build season when you finally have enough parts to start assembling....
#35
Re: 95 Hard at work
Re: 95 Hard at work
No no no no no... that would be crazy talk...
....yes. |
#37
Re: 95 Hard at work
Pneumatic brakes to resist pushing? I like it.
#38
Re: 95 Hard at work
Wow looks great. I hope one day my team will have the resources for a plasma cutter, it's amazing what you guys can fabricate this early in the season.
#39
Re: 95 Hard at work
Partnering with a vocational school was the best move we've ever made. I strongly encourage other teams to search out vocational schools in their areas. |
#40
Re: 95 Hard at work
#41
Re: 95 Hard at work
Are you worried about damage with the brake? I know 40 put a pneumatic brake on their robot in 2006 and it gave them so much trouble they took it off by Battlecry (maybe mid-season?). People just kept hitting bashing them over and over it wracked their frame since there was no give. Of course... your robot looks to have a lot less cheese holes than a Trinity robot, so maybe it isn't a problem.
#42
Re: 95 Hard at work
These are seriously awesome. They remind me of some of the older 111 robots.
#43
Re: 95 Hard at work
What we did to address the strength concern: with the belly pan mounted the air cylinder mounts are very close to three points of lateral stability: a dead axle, the bent-up part of the belly-pan, and the horizontal part of the belly-pan. They are also not designed to lift the robot completely off of the ground. The four 3/4in cylinders can generate a maximum combined force of ~106lbf, so assuming our robot weighs at least 107lb the center wheels will still be sharing some of the load, especially sideways where the air cylinder mounts are weakest. Thanks! |
#44
Re: 95 Hard at work
Slow day yesterday, a lot of planning, organizing, and tweaking rather than a lot of assembly.
Consolidated 6 compartmented boxes of electrical components into one nice, heavy-duty box: ![]() Started populating and mounting everything in the drive base, and even a little bit of wiring: ![]() |
#45
Re: 95 Hard at work
