Go to Post 99.9999% of the FIRSTers are really nice - Denman [more]
Unread 25-01-2014, 15:53
pabigfe97 pabigfe97 is offline
pabigfe97 is an unknown quantity at this point
IR Sensors
Hello All!
How can I code a Sharp IR sensor in Labview so that it accurately measures distance and changes in distance.
Thanks in advance for your help!
Unread 25-01-2014, 17:34
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
Re: IR Sensors
We used one in 2012 for detecting the balls in our hopper.
It was a sharp IR sensor.
Java code was something like this
AnalogChannel ballDetector = new AnalogChannel(channelNumber); //where channelNumber is the port you've plugged
public double getBallDetectorUpper(){
    double sensorVoltage = ballDetector.getVoltage();
    if(sensorVoltage > 4.0 || sensorVoltage < 0.0){        //dont add in bogus data points
        sensorVoltage = 0.0;
    return sensorVoltage;
Our code was a little more involved than that, but this is the general idea.
If you wanted to convert the voltage measured to a value in inches, there is usually a curve in the datasheet for the sensor which correlates voltages to distance. This can be used to generate an equation to convert voltage to distance.
We found that this wasn't necessary, at least for our uses in 2012. If the voltage was below a certain level a ball was considered present, otherwise a ball was not present. No need to determine the distance away in inches...
http://team2168.org
Unread 25-01-2014, 21:22
Doc Wu's Avatar
Doc Wu Doc Wu is offline
AKA: Al Gritzmacher
FRC #1507 (Warlocks)
Doc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant future
Re: IR Sensors
Originally Posted by pabigfe97 View Post
Hello All!
First of all, everybody, read what he asked. He said Labview.
What you didn't say was the model of the Sharp sensor. But don't even bother telling us that until you've taken that model number and put it into Google and found a spec sheet. That will tell you what kind of output it gives you. It may answer your question, or it may just let you ask a more specific question that people can give you help on.
Many such sensors give an analog output that is proportional to the distance. The spec sheet will give you a formula or a chart that shows the voltage that corresponds to a distance.
Good news is you have analog inputs on the Crio. They accept 0-5 volts. If the sensor also gives an output of 0-5 volts, you're good. If it's more, say 0-10 volts, you will need to scale it. That can be done as simply as a voltage divider with a couple of resistors.
If the sensor has some other output, say serial or I2C, you may be up to programming it or not. I don't know you level of programming ability.
But the first thing you need to know is what you're up against. The spec sheet will tell you that.
-= Mentor Lockport Warlocks -=- Team 1507 =-
Amateur Radio Callsign: AE2T
2016 Robot Inspector - Fingerlakes, Pittsburgh
2015 Robot Inspector - Pittsburgh, Champs. Judge Observer - Champs
2014 Robot Inspector - Tech Valley, Fingerlakes, Buckeye, Championship
2013 Robot Inspector - Fingerlakes, Buckeye, Championship
2012 Robot Inspector - Fingerlakes, Buckeye, Championship - Website Evaluator - Fingerlakes, Buckeye, Championship
2011 Robot Inspector - Fingerlakes 2011 Safety Advisor - Fingerlakes
Unread 25-01-2014, 21:42
BitTwiddler's Avatar
BitTwiddler BitTwiddler is offline
electronics/programming mentor
AKA: Mr Tanguay
FRC #1726 (N.E.R.D.S.)
BitTwiddler is on a distinguished road
Re: IR Sensors
If it's the Sharp 2D120X IR reflective sensor here's a snippet of Labview code that I used on our trainer. I set the threshold to 2 volts which corresponds to a object being sensed at about 7 cm from the sensor.
Name:	IR senser - begin.PNG
ID:	15956  Click image for larger version
Name:	IR sensor - Timed Tasks.PNG
Unread 25-01-2014, 22:48
Re: IR Sensors
That was added a few hours after the original post.
