"Timer Loop" Program
Hi
Recently our team has been struggling through our autonomous program by using some trial and error and hoping that we could get it to work. Unfortunatly we have hit a problem that is timming loops. I ran a search for timing loops on this site and found some info but have been unable to adapt it or even figure it out. I was wondering if some of you briliant programs could write a simple segment for our autonomous program. I would like to have PWM 1 to have a value of 254 or whatever "full forward" is when the program starts and have it run for .5 seconds at that speed then stop. It would be handy if you could explain what values would need to be changed in order to adjust the length of time the motor is on and how fast it goes. I greatly appreciate your help in this matter. Thank you. |
one way you could accomplish timing is using the basic controller's constant speed, the controller runs at about 38 Hz (38 times a second). if you wanted to count time you could have something like Time = Time + 1 + delta_t. Time would be the times the program has looped through, you add one to make it one more time and add delta_t in case the program "reset" because it took too long to respond (delta_t is the amount of packets missed) some syntax for the control could be
Time = Time + 1 + delta_t if Time < 19 then 'counts to about 1/2 second p1_y = 254 p3_y = 254 endif if Time > 19 then 'after 1/2 second robot stops p1_y = 127 p3_y = 127 endif if you want 1 second you could replace 19 with 38, because 38 cycles is approx. 1 second, use greater than and less than symbols because it'll do that action during that time period and also in case the program happens to miss that exact cycle it won't skip that phase of your code you would also have to define your variables, you don't have to use time, that's just something that i picked, you may also have to "define" (take out the comment in front of delta_t) and also set change c_delta_t CON 0 to c_delta_t CON 1 and include it in the serin line (look at the example above it for the correct placement in the line) |
i thought the controller looped the code once every 26 milliseconds? so you would make a little counting function in the main loop, and assume that for each additional value of the counter the program has run for another 26 milliseconds?
yes that is correct, the controller does loop every 26 milliseconds, which comes out to 38.46153846 times per second. that is why i use 38 as my approximation for 1 second. and yes, every 26 milliseconds my counter value would increase by one
ya i kinda suspected that but didn't really feel like running the numbers .. sorry
Also, make sure the initialized inputs that are turned on ie
c_p3_trig CON 1 is the same as the number of things in the SERIN. My word, we spent hours figuring this out. Please don't yell at me if I used some wrong terminology. I'm new! |
#7
It is recommended that the count-up-delta_t method, or the change in packet_num be used, as they don't skip. Every 26 ms, the Operator Interface sends a new packet of instructions, and each packet has a serial number, the packet_num. The Robot Controiler stores the packet_number for its own purposes, and reports it to you via the serin statement in your prohram if you select it. The RC also calculates the differrence between the current packet_num and the last one it stored, and will similarly pass this info on to your program. If your program starts to take too long in the loop when you add the last code, delta_t may rise to 2 even 3 (packets / time periods have been missed. Don't $@#$@#$@# U ME it makes an $@#$@#$@# out of you & me ![]() |
#8
How is it exactly that you could skip a loop thru the program?
#9
the way the program could skip a loop is if, for some reason, the rc doesn't send a response soon enough (26 milliseconds) then it'll restart w/ the serin command and the program stores the number of skipped loops into delta_t (resets back to 0 every time the program is fully looped through) (i think of delta_t as delta meaning change or difference in and t as time, or the difference of time since last loop went through)
#10
Alright all you smark people, pay attention. Whilst programming my team's robot, my mentor and I discovered sometheing rather unexpected: Our robot's autonoymous timing was solely dependent on the number of Debug statements we had entered into our program.
Trust me, we laughed at that. We initially had placed debug statements into our program to help us figure out exactlywhat all we were doing. When we decided removed a debug statement, the time was drastically shorter. The thing is, we only had three debugs entered! My point is, if worse comes to worse, perhapse you could try and add some debug statements to your code and see what happens, though I don't recommend it. ![]() |
#11
auto mode is gay, i hate it. oh btw, ours works
. To bad i can't release any secrets you you guys, or i would have to shoot every one of yas ![]() |
#12
Use the debug commands to troubleshoot the logic of your program, but then comment them out with the delimiter (') when you want the experience the overall effect of the "real" program. I hope this helps. |
#13
If you incremented your counter by 1+delta_t, the debug statements would have far less of an impact, however, it would still be affected because you wouldn't have the same resolution. |
#14
Hu. So that explains it. Thanks.
#15
Here's an idea for everyone that I really like using for our code: use the conditional compilation statements (only availible in the BETA compiler for PBasic 2.5).. so:
#define showdebug (some code) #if showdebug #then debug "This is my debug statement. Yay. " #endif (more code) That way if you have multiple debug statements you dont have to search your code for all of them, just comment out the #define and the debugs wont compile. |
| 2-week FIRST summer program @ WPI | ColleenShaver | General Forum | 20 | 31-05-2009 03:02 |
| The best fundraising program ever... | Petey | Fundraising | 2 | 12-09-2003 19:42 |
| Fried program slots? | Jeff Waegelin | Programming | 18 | 19-03-2003 18:08 |
| Ahh! Program trick confusing! | archiver | 2001 | 9 | 24-06-2002 02:26 |
| Credits for FIRST program. | archiver | 2000 | 6 | 24-06-2002 00:16 |
