Go to Post Then there's the electronics, pneumatics, and all that stuff on top that will magically make the ball score billions of points. That will add up to a lot of weight. - MrForbes [more]
Unread 25-01-2014, 22:02
Team3993Tom Team3993Tom is offline
FRC #3993
Team3993Tom is an unknown quantity at this point
solenoid button help
Ok so our plan is to have a few different types of buttons for our solenoids. For some reason our code inst working and any advise would be appreciated. (the last one is the toggle.vi that is in our teleop)
Name:	solenoid button begin.png
ID:	15959  Click image for larger version
Name:	solenmoid button teleopo.png
ID:	15960  Click image for larger version
Name:	solenoid button finish.png
ID:	15961  Click image for larger version
Unread 25-01-2014, 22:24
Re: solenoid button help
Are the LED indicators on the cRIO solenoid module turning on?
These are Single solenoids you have defined.
Single Solenoids don't go "Reverse"
Unread 25-01-2014, 22:25
FRC #3993
yeah they stay lit green but when I click the button it dost change.
Unread 25-01-2014, 22:34
Single solenoids are true/false devices.
They are either "On" or "Off"
Double solenoids would use "Forward" and "Reverse"
Unread 25-01-2014, 22:41
FRC #3993
Is there a way to do it with a single?
Unread 25-01-2014, 22:49
Please explain what you mean by forward and reverse. If you mean two states, a single solenoid also has two states.
Unread 25-01-2014, 22:57
Just change where you use "Forward" to "On" instead
and change "Reverse" to "Off"
Unread 25-01-2014, 23:01
FRC #3993
I'm trying to have a cylinder push out and come back by using buttons on my controller. I was able to get the toggle to work by switching it to on and off instead of forward and reverse, but for some reason the two button is not working even though I did the same thing.
Unread 25-01-2014, 23:05
When you continue to hold both buttons 3&4 down at the same time the solenoid module LEDs aren't changing?
Unread 25-01-2014, 23:12
FRC #3993
ok it is working now but sadly it wasn't what I was hopping it would be. The idea was to make it go out if I press button 3 and stay in that position, but then go back in when I press number 4.
Unread 25-01-2014, 23:21
Qbot2640's Avatar
Qbot2640 Qbot2640 is offline
AKA: Terry McHugh
FRC #2640 (Hotbotz)
Qbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond repute
Disclaimer - I'm not a programmer - but I understand the solenoid:
A solenoid has a normally open and a normally closed condition. If your steady state condition would be the closed (rod inside cylinder) then hitting the momentary button on the controller sends the command to activate and change that state - but when you let go, it will go back to steady state.
You could do a number of things to get what you want - use a joystick or switch on the controller rather than a momentary button - so it "stays" in the activated state - or you could program that the button changes the condition from off to on. Push once for out, push again for back in. Probably a bunch more programming options - like I said, that isn't my specialty.
2012 Palmetto Regional Winners (Thanks 2059, 2815, and 287).
2012 Newton 14th Seed
2013 Chesapeake Regional Imagery Award Winners
2014 North Carolina Regional Imagery Award Winners
2014 Greater DC Regional Team Spirit Award Winners
2015 North Carolina Regional Finalists (Thanks 3971 and 587)
Unread 25-01-2014, 23:22
Here are two approaches:
1) Incorporate a feedback node to remember what your last choice was.
2) Embed the solenoid Set into two Cases, one for each button, so that it only gets Set when a button is pushed. The False Cases would be empty.
Unread 25-01-2014, 23:31
FRC #3993
where is the feedback node?
Unread 25-01-2014, 23:33
Programming -> Structures
Unread 25-01-2014, 23:48
FRC #3993
Would the feedback be inside the case, connecting button to feedback then case, or case to feedback to set?
(by the way thank you for putting up with my stupid questions)
