Go to Post For all of you thinking three alliances... how big of a pain would it be to have three different bumper colors? - Jon Stratis [more]
Unread 01-25-2014, 07:26 PM
JohnFogarty's Avatar
FTC, I have returned.
AKA: @doctorfogarty @GarnetSq
FTC #11444 (Garnet Squadron)
Re: pic: Did Somebody Say Defense Game?
This makes me glad we chose 6CIM drive.
John Fogarty
"Head Bot Coach" FRC Team 4901 Garnet Squadron
Former Student & Mentor FLL 1102, FTC 1102 & FTC 3864, FRC 1102, FRC 1772, FRC 5632
Unread 01-25-2014, 07:39 PM
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #0703 (Phoenix)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
Originally Posted by Chris is me View Post
Originally Posted by Andrew Lawrence View Post
Originally Posted by roystur44 View Post
Cross your fingers that it will turn without popping the breakers.
Actually, they're missing a couple of wheels. (2007 joke)
If it's anything like what they've done before, the wheels are in a bit of an arc, so it acts more like a 6WD drop than a 4WD "bounce turn".
Looks like it'd be more of an 8WD, but I could be wrong.
I don't see this as having much higher turning scrub than a six wheel drive. In theory, this system would behave like a tread drive and this would turn even without drop. I guess we shall see!
Our wheels are set at a 32 foot arc, which allows the drive to act, more or less, like a 6 or 8 wheel drive at any given time. What we've found over the years, however, is that during a pushing match with a typical 6WD robot, the forces of the two robots can actually push 6WD robots onto their back set of wheels and lift their front and middle ones up (even just a little), thus reducing their traction and making them effectively 2WD robots. Having extra wheels on an arc helps ensure constant contact with the floor during all conditions.
Originally Posted by Garrett.d.w View Post
...If I were holding the joysticks in this case :
That pretty much sums up what I'm expecting.
Originally Posted by Duncan Macdonald View Post
Is this a similar design to what your team ran in 2008? If so, what reliability changes were made?
2008 robot
Context (Still one of the classiest decisions in FIRST history)
2008 was an interesting case, we had a situation where we had a custom gearbox, that had a 3rd stage consisting of an 8 tooth gear that undercut a 50+ tooth cast iron gear, which was custom made (with a 3 week lead time to get more) and we had forgotten spares (and we were in Canada). This years robot, by comparison, uses standard VEXPro 3 CIM Ball Shifters, with parts we can get easily, and if necessary pick up from The Robot Space (one of the new VEXPro partners), less than an hour away.
The drive system itself is also much closer to our 2007 bot due to the use of gears to drive the wheels, rather than chain, and a very similar gearbox configuration to the drive we had that year. With the exception of a bearing failure in the finals of West Michigan (which we went on to win anyways), there was virtually no reliability issues with the 2007 drive system.
Originally Posted by Animal Control View Post
Yes. Can you sent a video with it running
Soon, I'm hoping we have it driving next week.
Originally Posted by magnets View Post
Originally Posted by Bryce Paputa View Post
Adding wheels doesn't really increase your traction/pushing power, does it? I'm sure that the extra width helps, but not the number.
Adding surface area in contact with the ground (up to a point) increases traction. It doesn't matter if it's through wider wheels, or more wheels. If friction worked just the way the coefficient of friction says it will, then neither width nor number of wheels will affect traction at all. You could have three 0.1" thick wheels, and have the same amount traction, but friction doesn't follow the super simple columbic prediction, especially on carpet.
Exactly, our wheels this year are also wider than we've used before (1.5in wide this year, compared to 1in past years), so we're hoping they will provide us with a bit more traction.
Originally Posted by wilsonmw04 View Post
How long are you going to have in a pushing match with a 6 cim drive before you start popping breakers?
We had no issues with the individual 40A breakers on our 2007 robot (the predecessor to this design), now, whether or not the 2 additional MiniCIMs cause the main breaker to pop is another question. We're using such a low low-gear that we should loose traction before stalling the motors though (at least, this has been the case on past machines).
Apologies for the wall of text, just figured I'd answer all the questions in one go.
Unread 01-25-2014, 07:46 PM
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
Their 2007 'bot for reference.
Unread 01-25-2014, 09:19 PM
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
well, you should be fine operating at 39amps per motor for a while
And if you are worried about the 234 amps on the main breaker, allow me to show you the current graph as per the manufacturer
As you can see, you can draw 200% (240 amps) for 10 seconds minimum, as per the specifications
EDIT: link fixed?
Unread 01-25-2014, 09:24 PM
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
link is broken, please try again. I'm worried about the snap fuses. I've seen what a resetting snap fuse does to a robots drive train. It isn't pretty.
Unread 01-25-2014, 09:37 PM
nathannfm's Avatar
nathannfm nathannfm is offline
AKA: Nathan
FRC #3940
nathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant future
Any reason you chose to assemble the 2 gearboxes identically instead of mirror images (which would have made the drive symmetrical)?
[2016-20??]: Mentor: FRC Team 3940"CyberTooth"
[2013-2016]: Mentor: FRC Team 365 "MOE"
[2012-2013]: Mentor: FRC Team 3929 "Atomic Dragons"
[2011-2012]: Mentor: FRC Team 365 "MOE"
[2008-2011]: Student: FRC Team 365 "MOE"
[2007-2008]: Student: FTC Team 365 "MOE"
[2005-2007]: Student: FLL Team "The MOEstangs"
Unread 01-25-2014, 09:38 PM
I am Dave! Yognaut
AKA: Brian Bray
Really? I can see it just fine.
Anyways, that pic is a screenshot from this pdf, page 34 you will find our switch.
So long as you do stay within the 40amps per motor, you should not need to worry too much about the main
Unread 01-25-2014, 10:07 PM
cbale2000's Avatar
AKA: Chris Bale
FRC #0703 (Phoenix)
No particular reason, its just how they were assembled. In the past we would use identically assembled gearboxes (or driving one gearbox to different wheel) for maintenance reasons, since pulling a gearbox with a long hex shaft output off is difficult when the boxes are right up against each other. This year the gearboxes are so huge though, it really doesn't make a difference.
We have to pull the panels apart when we install the idler gears anyways, so we may yet change the configuration of the one gearbox, especially since it's not hard to switch.
Unread 01-25-2014, 10:09 PM
wilsonmw04's Avatar
Coach
yep, still broken for me. the 40 amp resetting fuses are what scare me. I have never seen a main blow, but the quick resetting 40's popping = a bad day with robots.
Unread 01-25-2014, 10:17 PM
cbale2000's Avatar
AKA: Chris Bale
FRC #0703 (Phoenix)
Not saying it can't happen, but in my 8 years on my team I've never seen us trip a 40 amp breaker.
Correct me if I'm wrong here, but doesn't adding the 3rd motor to the gearbox take some of the load off of the other two, thus making a breaker reset less likely?
Unread 01-25-2014, 10:20 PM
Andrew Lawrence
Posts: n/a
In normal driving, it does take a bit of load off the other motors, but in a pushing match where all motors are giving maximum output you have a larger chance of tripping the breaker with a 6 motor drive than a 4 motor drive. The solution is to just not get into heavy and sustained pushing matches.
Unread 01-26-2014, 12:49 AM
Deke's Avatar
Deke Deke is offline
no team (No Team)
Deke is a jewel in the roughDeke is a jewel in the roughDeke is a jewel in the roughDeke is a jewel in the rough
Correct, current = torque. So by adding a 3rd motor to each gearbox you reduce the load on the 40amp breakers while the load on the main breaker will remain the same for the same torque, regardless of motor count.
Unread 01-26-2014, 01:32 AM
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
To answer your question, yes I did.
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
Unread 01-26-2014, 01:40 AM
wilsonmw04's Avatar
Coach
so adding three motors doesn't increase torque? interesting.
Unread 01-26-2014, 02:24 AM
MooreteP's Avatar
MooreteP MooreteP is offline
Zen Archer
AKA: Senor Mas
FRC #0571 (Team Paragon)
MooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond repute
Mad Crazy Drivetrain.
IMHO, this may be the year that Mecanums make it to Einstein.
A defensive Robot that can strafe in the Goalie zone or between two robots passing is more akin to defensive play in Hockey, Soccer, and Basketball.
Pushing or preventing is another issue, but that may not be the key to defense in Aerial Assist.
