Go to Post And another big factor in winning. Luck. - Carol [more]
Unread 21-01-2014, 08:09
Mr. 1033's Avatar
Mr. 1033 Mr. 1033 is offline
AKA: Paul E. Lathrop
FRC #1033 (Team CLUTCH)
Mr. 1033 is a jewel in the roughMr. 1033 is a jewel in the roughMr. 1033 is a jewel in the roughMr. 1033 is a jewel in the rough
[FTC]: FTC Multiplexer
Has anyone programmed the Multiplexer with robotc?
We have been working on it and found the following resource:
http://www.robotshop.com/media/files...st-nsx2020.pdf
We were kind of hoping it was a little simpler.
Anyone know of any other way to use it?
Thanks!
Unread 21-01-2014, 14:41
Sasha Sasha is offline
AKA: Alexander Kirillov
FTC #4137 (IslandBots)
Sasha is just really niceSasha is just really niceSasha is just really niceSasha is just really niceSasha is just really nice
Re: [FTC]: FTC Multiplexer
Yes, we are using the sensor multiplexor, using the 3rd party driver suite
Here is the appropriate part of our autonomous program. Hope it helps.
#pragma config(Hubs,  S2, HTMotor,  HTServo,  HTMotor,  none)
#pragma config(Sensor, S1,     HTSMUX,              sensorI2CCustom)
#pragma config(Sensor, S3,     IRsensor,       sensorI2CCustom)
#pragma config(Sensor, S4,     GyroSensor,     sensorI2CHiTechnicGyro)
#pragma config(Motor,  motorA,          BlockDrop,     tmotorNXT, PIDControl, encoder)
#pragma config(Motor,  mtr_S2_C1_1,     winch,         tmotorTetrix, openLoop)
#pragma config(Motor,  mtr_S2_C1_2,     right,         tmotorTetrix, openLoop, encoder)
#pragma config(Motor,  mtr_S2_C3_1,     arm,           tmotorTetrix, openLoop)
#pragma config(Motor,  mtr_S2_C3_2,     left,          tmotorTetrix, openLoop, reversed)
#pragma config(Servo,  srvo_S2_C2_1,    servo1,               tServoNone)
#pragma config(Servo,  srvo_S2_C2_2,    servo2,               tServoNone)
#pragma config(Servo,  srvo_S2_C2_3,    servo3,               tServoNone)
#pragma config(Servo,  srvo_S2_C2_4,    servo4,               tServoNone)
#pragma config(Servo,  srvo_S2_C2_5,    servo5,               tServoNone)
#pragma config(Servo,  srvo_S2_C2_6,    grabber,              tServoStandard)
//*!!Code automatically generated by 'ROBOTC' configuration wizard               !!*//
#include "drivers/hitechnic-gyro.h"
#include "drivers/hitechnic-irseeker-v2.h"
#include "drivers/hitechnic-sensormux.h"
#include "drivers/lego-light.h"
#include "JoystickDriver.c"
const tMUXSensor LightSensorLeft = msensor_S1_1;
const tMUXSensor LightSensorRight = msensor_S1_4;
//  Global variables
int initialLightLeft, initialLightRight;
//  Checks whether light sensor sees white line
bool LeftOnBlack(){ //returns true if left light sensor is on black
  return (LSvalNorm(LightSensorLeft) <= 10 + initialLightLeft);
bool RightOnBlack(){ //returns true if right light sensor is on black
  return (LSvalNorm(LightSensorRight) <= 10 + initialLightRight);
//                                    initializeRobot
void initializeRobot()
  // Place code here to sinitialize servos to starting positions.
  // Sensors are automatically configured and setup by ROBOTC. They may need a brief time to stabilize.
  LSsetActive(LightSensorLeft);//turn on the light
  LSsetActive(LightSensorRight);//turn on the light
  initialLightLeft=LSvalNorm(LightSensorLeft);
  initialLightRight=LSvalNorm(LightSensorRight);
  return;
//                                         Main Task
task main()
  initializeRobot();
  StartTask(printStuff);
  waitForStart(); // Wait for the beginning of autonomous phase.
  motor[right]=30;motor[left]=30;
  //wait until one of the sensors sees white
  while (LeftOnBlack() && RightOnBlack() ) {
   wait1Msec(1);
  motor[right]=0;motor[left]=0;
  PlaySound(soundBeepBeep);
  wait10Msec(50);
Unread 26-01-2014, 02:55
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Our team also uses the HiTechnics Sensor MUX. In fact, we use two of them. Our robot is fully loaded with sensors (8 in total). We actually wish to add one more but ran out of ports, the other two sensor ports are for the motor chains.
