Go to Post Every event that starts with "a little bit of fun" has the potential to end in disaster. Please think about all possible outcomes before you do anything stupid. - sanddrag [more]
Unread 25-01-2014, 10:47
mistersands mistersands is offline
FRC #4528 (Automatons)
mistersands has a spectacular aura aboutmistersands has a spectacular aura aboutmistersands has a spectacular aura about
Battery charging?
We are using the default batteries and the Schumacher speed charger.
Should we plug in batteries after each use, or let them fully discharge? Does it make a difference in battery life?
Unread 25-01-2014, 11:53
jdh042397's Avatar
jdh042397 jdh042397 is offline
Being a nerd really pays off!!
FRC #4063 (TRikzR4kiDz)
Team Role: Electrical
jdh042397 is an unknown quantity at this point
Re: Battery charging?
When we use a battery, we normally use a full charge then just continuously run from there. We change it out when we notice a difference in operation, like if a shooter doesnt work as effectively or if we drive slower than usual. As far as I know it really doesnt make a difference in the life of the battery.
2014 Hub City Regional Engineering Inspiration
2012,2013,2014 Alamo Regional Gracious Professionalism
2014 Dallas Regional Gracious Professionalism
2013 Alamo Regional Winners (2468 & 2789)
2013, 2014 Hub City Regional Finalist
"Robotics are beginning to cross that line from absolutely primitive motion to motion that resembles animal or human behavior."
J. J. Abrams
Unread 25-01-2014, 12:48
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
The battery's life expectancy is expressed in the number of charge/discharge cycles and the number of cycles is directly related to the average depth of discharge. The deeper the discharge lower the expected number of cycles that the battery will last. Also a battery that is stored in a less than fully charged state will tend to develop sulfate deposits at a higher rate than one that is stored fully charged.
So at competitions put your batteries on the charger as soon after each match as possible. When practicing try to avoid letting the battery discharge to the point that you notice a drop in robot performance. When you are practicing have the driver's note the voltage on the driver's station display. Once the battery voltage shows as 11.0 v or lower when the robot is idle it is time to change the battery. Doing both of those things regularly will maximize the useful life of the battery.
Unread 25-01-2014, 16:14
Attachment is from the MK datasheet
Name:	MK ES17-12.png
Unread 25-01-2014, 19:09
brycen66 brycen66 is offline
FRC #1678 (Citrus Circuits)
brycen66 is just really nicebrycen66 is just really nicebrycen66 is just really nicebrycen66 is just really nice
You should change the battery between every match in competition. This will prevent efficiency and accuracy loss due to low voltage.
Unread 25-01-2014, 20:10
DonRotolo's Avatar
Back to humble
FRC #0832
Do NOT EVER* allow the batteries to fully discharge. This will really shorten their life significantly.
These batteries - indeed, any lead-acid battery - will last longest when the number of minutes that it is not fully charged is kept to a minimum. So charge it as often as you can, any time you can.
When leaving the batteries alone, like over summer vacation, remember they discharge 15-25% per month, so charge them as often as possible so they are not damaged.
*Never, never ever!
Unread 25-01-2014, 23:33
What Don and Ether said. The need to discharge batteries to zero volts was for old style NiCad battery chemistry and is no longer needed or recommended for any battery type.
Unread 26-01-2014, 08:48
DonRotolo's Avatar
Back to humble
FRC #0832
Including modern NiCd chemistry...
