Go to Post I believe that "going home a winner" is more a matter of perception than anything else. - JesseK [more]
Unread 26-01-2014, 10:54
Wazzaps Wazzaps is offline
FRC #1573
Wazzaps is an unknown quantity at this point
Question Gyro problems
OK so we wanted to install a gyro, and we did it, no explosions yet, but the values aren't correct at all, they randomly fluctuate w/o any response to the actual gyro rotation. We wired all correctly, and programmed according to
Any help? <- my mentor's addition
Unread 26-01-2014, 11:20
Kevin Phan's Avatar
Kevin Phan Kevin Phan is offline
College Student
FRC #0357 (Royal Assault)
Kevin Phan will become famous soon enoughKevin Phan will become famous soon enough
Re: Gyro problems
When using a gyro, the gyro will not at first give a degree that you do not expect. If you are thinking in the form of 0-360 degrees. You need to use the modular division to get the 0-360 you want. I noticed in your begin that your gain is set to 125 mV/sec, you want to refer to the first technical resources for setting up the gyro. It is actually 7 mV/sec. When setting up the gain it should have .007 as the constant for the set gain vi. Also you probably do not want to continually read a gyro in the tele-op vi, since LabVIEW will continually read the gyro and eat up your processing time. You want to use the example to figure out a loop delay and move your gyro reading into Periodic tasks.
Another note to add is that a gyro will continually add on to itself due to factors you can't control. To mitigate this, you would want to reset your gyro at points where it will not affect your measured heading.(i.e. Reset gyro when the robot faces the drive station.)
Unread 26-01-2014, 11:52
FRC #1573
Re: Gyro problems
we tried changing the value but it still didnt help.
ill explain in more detail what you can see
when you deploy the robot code it shows a value that gets higher and higher, stops and then lowers itself or raises itself again.
can anyone explain why?
Unread 26-01-2014, 13:54
jbsmithtx's Avatar
jbsmithtx jbsmithtx is offline
FIRST Fanatic
AKA: Josh Smith
FRC #4206 (RoboVikes)
jbsmithtx is a jewel in the roughjbsmithtx is a jewel in the roughjbsmithtx is a jewel in the rough
Re: Gyro problems
Try using the gyro "reset" vi. Our team had this same problem last year, and this fixed it
Re: Gyro problems
If you wired it correctly and programmed it correctly and the gyro is working, then you wouldn't be having a problem. Pictures of your actual wiring and actual code would go a long way help others figure out your problem.
Common problems that people have are:
Not powering the Analog Breakout
Wiring to the Temperature output instead of rate
Plugging it in backwards
Not using Analog Input 1 or 2.
Reading the gyro is not taxing. There is no problem reading the gyro in every loop in telop. All of the hard work is done in the background in the FPGA, all the gyro get does is get the latest value.
Unread 26-01-2014, 14:05
foote stepped in
AKA: E. Foote
FRC #0868
Re: Gyro problems
Make sure you're not reading the temperature pin instead of the angular rate pin.
Be Healthy. Never Stop Learning. Say It Like It Is. Own It.
Like our values? Flexware Innovation is looking for Automation Engineers. Check us out!
Unread 08-02-2014, 16:02
Roshang Roshang is offline
FRC #0204
Roshang is an unknown quantity at this point
Re: Gyro problems
Hi,
I've been trying to implement a gyro into our code so that we can do field-oriented Mecanum Drive. I've gotten the gyro and the mecanum drive to work in their own programs. However, when I put them in the same program, neither work. I've tried it with both in teliop and with the gryo code in periodic storing angle to a global variable, which is read in teliop with the drive control. With my code as it is right now, if I only deploy teliop.vi from labview, the gyro works. But with the entire code deployed, it doesn't. I'm at my wit's end trying to figure out what's wrong. Any ideas?
Thanks
ID:	16162  Click image for larger version
ID:	16163  Click image for larger version
ID:	16164  Click image for larger version
Unread 08-02-2014, 16:37
Re: Gyro problems
You can't put a while loop in teleop. See Tutorial 7- Integrating Examples into Robot Code.
