Go to Post Mess up something important and you lose. Just like real life. - DonRotolo [more]
Unread 19-01-2014, 20:00
hiyou102's Avatar
hiyou102 hiyou102 is offline
hiyou102 has much to be proud ofhiyou102 has much to be proud ofhiyou102 has much to be proud ofhiyou102 has much to be proud ofhiyou102 has much to be proud ofhiyou102 has much to be proud ofhiyou102 has much to be proud ofhiyou102 has much to be proud of
Re: Getting Smartdashboard 2.0 working
Originally Posted by byteit101 View Post
Hmm, that is interesting and confusing. Would you mind pasting the sha1sum of sfx.jar, sfxlib.jar and sfxmeta.jar?
Whoa, just testing right now with 7u51 I get a strange error that we only saw on Java 8 but its different to what you have... Would you mind trying with 7u45 if you can?
Using my linux machine that has 7u45 (can't get to the Windows computer I've been testing on today) it spits out the following error code:
denis@denis-Aspire-3830TG / $ sudo  java -jar sfx.jar
Exception running Application:
#<NameError: uninitialized constant JRubyFX::Controller::FxmlLoader>
org/jruby/RubyModule.java:2684:in `const_missing'
file:/sfx.jar!/jrubyfx/imports.rb:71:in `const_missing'
file:/sfx.jar!/jrubyfx/controller.rb:334:in `get_fxml_loader'
file:/sfx.jar!/jrubyfx/controller.rb:117:in `load_into'
file:/sfx.jar!/jrubyfx/core_ext/stage.rb:82:in `fxml'
classpath:jar-bootstrap.rb:74:in `start'
org/jruby/RubyBasicObject.java:1536:in `instance_eval'
file:/sfx.jar!/jrubyfx/module.rb:49:in `with'
classpath:jar-bootstrap.rb:73:in `start'
file:/sfx.jar!/jrubyfx/java_fx_impl.rb:119:in `launch_app_after_platform'
org/jruby/gen/InterfaceImpl777276342.gen:13:in `run'
My sha1sum's are:
64fcdf3b0581b7984f9bb46f445d76327b0c4d4e  sfx.jar
1c9eb494fe5b887e13e65a5df6afaee722c15d86  sfxlib.jar
acc23b6c9f2dab9ec9f41085c1112d55e9875b31  sfxmeta.jar
Team 4334 2012-2014
Unread 21-01-2014, 16:46
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
Hmm, the latest sums are
f87153004a148ca2e1af6e855ee61ad9e6dedd21 sfx.jar
8af943793e339c5ada2e01714f82ade68d886fc5 sfxlib.jar
ea4181a899de37042f393a5536a143ccc68a510d sfxmeta.jar
could you re-download sfx.zip from here and try again: http://frcbuilder.wpi.edu:8190/job/S...tifact/sfx.zip
Watchdog.Kill();
Unread 25-01-2014, 14:39
mryfrmr's Avatar
mryfrmr mryfrmr is offline
AKA: Mary Farmer
FRC #0191 (XCATS)
mryfrmr is an unknown quantity at this point
Hi, I am getting the same message, and I don't see the sfxlib.jar file in the sfx.zip file downloaded from the above link.
Unread 26-01-2014, 12:48
byteit101's Avatar
sfxlib and sfxmeta will appear once you run sfx. either way, you can still check the sha1sum of sfx individually
Watchdog.Kill();
Unread 29-01-2014, 21:58
riftware riftware is offline
Parent Mentor
AKA: Andrew Chandler
FRC #0031
riftware is an unknown quantity at this point
I found something interesting on Windows 7 64bit. It won't work from the standard user/sunspotfrcsdk directory structure if your name has a space in it. I tried moving the sfx.jar and plugins directory to c:\apps\sfx and it worked fine
