Go to Post [I] [/I]I think this may be some kind of record. We got through 9 entire posts before someone mangled the spelling of mecanum. [I] [/I] - Ether [more]
Thread Tools Rating: Thread Rating: 11 votes, 5.00 average. Display Modes
Unread 25-01-2014, 15:25
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
theawesome1730 will become famous soon enough
Re: Autodesk Vault 2014
Just an update: we got our rack servers and are working to transfer the Vault to the server but want to know the best way of doing it. Are any of you familiar with this process?
2015 GKC Engineering Inspiration
2015 Colorado Winners
Unread 25-01-2014, 18:19
inventor_phild inventor_phild is offline
inventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant future
Here is a link to the Wiki help page.
http://help.autodesk.com/view/VAULT/...E-EA142103EB03
I will check for more detailed results on your request, but it looks like a search for "transfer vault" should get you what you want.
Phil Dollan
Autodesk Inc.
Autodesk Inventor and Fusion 360
Unread 25-01-2014, 19:10
Using the link above, search for Vault Data Transfer Utility
Phil Dollan
Autodesk Inc.
Unread 26-01-2014, 01:24
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Originally Posted by bachster View Post
Thanks for the suggestion. Unfortunately, the buttons are still grey.
In my experience, this has been due to the project file not being correctly set. In Inventor, go to the Inventor menu (big I in the top left) and click Manage->Projects. Browse to your vault project file (wherever it is located locally), and make sure there's a check mark next to it after selecting it.
Unread 26-01-2014, 14:42
I agree with Sanddrag, it looks like a project file issue.
In addition to the previous suggestion make sure the project file type is set to Vault.
The attached image shows a Single User project file. If your project file looks like this then you need to create a new project file using the New Vault Project option.
Phil Dollan
Autodesk Inc.
Unread 26-01-2014, 15:00
Morgan1825's Avatar
Morgan1825 Morgan1825 is offline
Co-CAD Leader and Programmer
AKA: Firecracker
FRC #1825 (Metro Homeschool Robotics)
Team Role: Student
Morgan1825 is an unknown quantity at this point
Hello,
Im not sure if i have Vault. Is it called Autodesk Basic Vault 2014? Also, what log-in do you use? The one that you use to download CAD? Or do you use the Autodesk Cloud account? Sorry for all the questions, im a very curious student.
Thanks,
Morgan1825
Oh, and I could use some help on how to use it. I ave no clue how it works. Thanks.
Unread 26-01-2014, 15:06
What you have would be the vault client. To use vault, you need to set up a computer with the Vault server, which is a separate download and install. It is possible to have the client and server on one computer, for a single user, but a more typical implementation would be to use a dedicated computer for the server. You can have up to 10 users on Windows 7 and more than that on Windows Server. I use Windows Server 2008 R2 Enterprise on an older Dell Poweredge 1850 with 10k RPM SCSI drives and 8 give of RAM.
Unread 26-01-2014, 15:19
Morgan1825's Avatar
AKA: Firecracker
Team Role: Student
Ah, Thank you. Can I still use the Basic Vault? What will it do? Thanks again
Unread 27-01-2014, 01:29
bachster's Avatar
bachster bachster is offline
AKA: Katie Bach
FRC #2052 (KnightKrawler)
bachster has a brilliant futurebachster has a brilliant futurebachster has a brilliant futurebachster has a brilliant futurebachster has a brilliant futurebachster has a brilliant futurebachster has a brilliant futurebachster has a brilliant futurebachster has a brilliant futurebachster has a brilliant futurebachster has a brilliant future
Thanks for your help Sanddrag and Phil! I had to create a new Vault project file in a separate location - I had some errors trying to create a new one because there were other project files and content center files within the same folder path. I'm up and running now!
