Re: pic: Average 2014 Chassis
We measured about 17 Amperes free current using the stock AM gears, and about 10 Amperes free current after replacing with VexPro gears. Gears were well greased for both tests, and the results were repeatable.
AM steel gears appear rougher, while VexPro 7075 gears have smoother finish. Also, VexPro gears are AGMA 11 -- closer tolerances, better fit. The free current really tells the story, though. Lower friction, less power wasted. |
I believe the VexPro gears are coated with some Teflon/ceramic mixture that reduces friction. In addition to the reasons mentioned above.
Is the center wheel dropped? If so, what was the thought process for using omni's? Last year, my team did the same thing sort of against my wishes because I didn't see the purpose. It seems to me that as long as you power every wheel and only 4 can physically be on the ground, then turning will never be an issue. Despite that question though, looks like a great drive train. Nice job guys!
We didn't drill any extra holes for axles in the AM14U chassis, so yes, the omniwheel axles are about 1/8" higher than the other two axles when the chassis edges are parallel to the floor. This is effectively about 1/16" center wheel drop. I agree that a custom chassis would not need a center wheel drop for this kind of omniwheel setup.
