Go to Post Plot twist: I'm actually Dean Kamen, and I've seen so many water game suggestions that we're now considering it. :deadhorse: - Derpancakes [more]
Unread 25-01-2014, 23:55
M.Kong-Sivert M.Kong-Sivert is offline
AKA: Mackenzie Kong-Sivert
FRC #2375 (Dragon Robotics)
M.Kong-Sivert is an unknown quantity at this point
Out of Control Drivetrain
Some of my teammates and I have spent all day today, and have blown a jag, trying to get our robot to stop malfunctioning. Every time we turn on the robot, the two CIMs that make up our drivetrain spin at full power even though nobody is touching the controls. We replaced the program with the FRC LabVIEW default code and made sure the PWM positions corresponded to the correct motors according to that program, so we know it's not a programming issue. We replaced the PD board, the sidecar, the cRIO, and the jag, so it's not a problem with any of those pieces. Can somebody figure out what's wrong with our robot? Thank you.
Unread 25-01-2014, 23:58
geomapguy's Avatar
geomapguy geomapguy is offline
Centenary '18
AKA: Graham Maxwell
FRC #1818
geomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud of
Re: Out of Control Drivetrain
Honestly sounds like faulty motor controllers.....have had the same thing happen to our team
The Cowboys - FIRST Robotics Team #1818 2015-
The Bolton Bear Bots - FIRST Robotics Team #3666 2011-204 (30-26-0)
2014 Oklahoma Regional - 20/62 (6-4-0), 5/62 in OPR
2014 Arkansas Regional - 14/39 (8-7-0, Quarterfinalists with 1706 and 1939), 24/39 in OPR
2013 Lone Star Regional Dean's List Finalist!
2013 Lone Star Regional - 22/57 (6-5-0), 17/57 in OPR
2012 Bayou Regional - 16/49 (6-5-0)
2011 Dallas Regional - 10/52 (4-2-5, #6 Alliance Captain, Quarterfinalists with 2948 and 3350)
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
Try unplugging your joysticks/control method and reattaching them. Sometimes, someone just happens to be holding the joysticks in some other position than their default "home" position. Make sure when you are plugging them back in that they are correctly centered.
I'm right 90% of the time, so why worry about the other 3%?
Unread 26-01-2014, 00:45
Do the motors spin when the robot is not enabled? They should not.
Are the Jags wired correctly? They are not protected and could have shorted due to a wiring mishap.
Unread 26-01-2014, 02:13
If you remove the DB-37 cable from the digital sidecar, does the robot still go crazy? With the cable removed, are all three power LEDs on the digital sidecar brightly lit?
Unread 26-01-2014, 07:09
I'm pretty sure the jags are wired correctly, but I took some pictures of it, so someone with a fresh pair of eyes can see if there is a problem.
ID:	15967  Click image for larger version
Name:	Connection to PD Board.JPG
ID:	15968  Click image for larger version
Name:	Electrical Setup.JPG
Unread 26-01-2014, 08:36
page2067's Avatar
page2067 page2067 is offline
AKA: rick page
FRC #2067 (Apple Pi)
page2067 has a spectacular aura aboutpage2067 has a spectacular aura aboutpage2067 has a spectacular aura about
Looks to me you have the Jaguar wired backwards - the wires from the PD board with yellow tape should go to the left side - marked with a V+. the right side is marked with a M+ is the output to go to the motors.
see: http://content.vexrobotics.com/docs/...e_20130215.pdf
As Al said they are not protected from being wired in reverse so the Jaguars may be dead now.
Unread 26-01-2014, 10:07
Tem1514 Mentor's Avatar
Tem1514 Mentor Tem1514 Mentor is offline
FRC #1514
Tem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to behold
Sure looks like the power and motor wires are wired on the wrong inputs/outputs to me as well.
Looking at your pictures, the wires that have the yellow/white electrical tape on them, do these wires go to the PDB? If they do, you have it wired wrong as the colored tape wires must go on the same side as the PWM cable.
Look carefully on the Jag and you will see + - on one side (for power in) and on the other side M+ M- (to go to the motor).
Unread 26-01-2014, 12:05
Cecil's Avatar
AKA: Alex Hummel
As they have said, your Jaguars are wired backwards. Power goes in on the left side, goes out on the right. Personally, I would not risk using those controllers in a competition environment. If they are not blown up now, there is a very high chance that they will fail when you really don't want them to.
Throw them away, or make them into a display and label which wires go where on them. I guarantee nobody will ever make the mistake again if they have a physical guide on how to do it.
Unread 26-01-2014, 13:45
Is that a 100% money-back guarantee?
Unread 26-01-2014, 17:32
Motors going full speed immediately on application of power is a definite symptom of having the Jaguar power connected to the motor terminals and vice versa. I was going to suggest looking at that even before seeing the photos.
The Jaguar terminals are 1) labeled and 2) color-coded. In spite of that, people get it wrong. There's no way to prevent it.
Unread 26-01-2014, 22:29
Cecil's Avatar
AKA: Alex Hummel
I know it worked 100% for our team at least (of course, we now have someone double and triple check the wiring so it doesn't happen again).
I also noticed they removed screws and replaced them with some of their own. That in itself can be confusing, especially for people who don't know that the inputs are marked on the casing. I like the new labels on all of the new ones. A bright yellow label is hard to miss, but I agree that it can still be overlooked.
Unread 26-01-2014, 23:58
yash101 yash101 is offline
AKA: null
I think you may have shorted some FETs inside the Jags. Try replacing one jag and wire it 100% correctly. If that solves the problem to that motor, kudos to you...You've found the problem. Now, go and replace the Jag on every other motor and wire it the same way as the working motor.
Read through the FRC 2014 electrics setup guides and the Jag manuals as they will prevent you from turning a nice, well made cake into a burnt one.
If the problem persists, I suggest that you postt a video of it, so we can debug what is happening.
