Re: pic: AM3CIM4U with Grayhill
Can I ask why you're using the 61R vs the 63R?
We've been using the 63R256 on machines back to 2010, we've just kept ordering the same parts, I wasn't aware there were other models similar to the 63R. I took a look at the specs between the two parts, and it seems like the only difference is that the 63R part number has a higher lifetime rating and higher max RPM rating. 61R, 10 Million cycle lifetime, 300 RPM 63R, 300 Million cycle lifetime, 5000 RPM Price points seem to be the same on octopart |
I don't know that we are.
Like you, we have been using the same encoders for a few seasons now. All I know for sure right this minute (Sunday evening, no access to team build space at the high school) is what you can see in the picture -- i.e., five pins. I agree the 63 series specs are better for this application, so IF we were able to get those encoders at the time, then we would have selected them. Sometimes FRC teams have to use what is in stock during build season. ![]() |
What kind of drivetrain are you using them on? How will you use that feedback? I understand the needs in swerve but I am less knowledgeable about how to apply them for something like the AM14u.
Specifically on the AM14U you can better control how far/how many rotations each side of the drive rotates which makes driving to a desired location much easier to do/program. -Nick |
I can't really tell how from the picture, how did you extend the shaft and attach it to the end of the encoder? What parts did you use?
Two helical beam shaft couplings from McMaster, and a 3.5" long piece of 1/4" rod.
#7
What are the advantages of using these encoders over the ones from AM?
#8
why do you use these instead of the ep4's from AM?
#9
We switched to Grayhills because they are more rugged than the EP4. It is nice to be able to drive aggressively and not worry about whether your auto mode will be working for the next match. |
