Go to Post We are behind you 100% (more if needed)! - Clem1640 [more]
Unread 26-01-2014, 18:08
peng432 peng432 is offline
FRC #3236
peng432 is an unknown quantity at this point
Help with Programming Pnuematics
Hi,
Our team recently lost the majority of its programmers and where switching over to Java, i understand java a little and where using robot builder to make it a bit easier. My question is how do you code pneumatic's in general and even then how would you use that in robot builder? I lurked a little to try and find out but my adventure didn't give me anything. So any help would be Greatly appreciated!!
Unread 27-01-2014, 07:42
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: Help with Programming Pnuematics
Originally Posted by peng432 View Post
Hi,
You'll want to create a Solenoid first.
Solenoid solenoid1 = new Solenoid(1);
Then you'll want to tell the solenoid to activate.
solenoid1.set(true);
Or deactivate.
solenoid1.set(false);
If you have a double acting cylinder you'll need teo solenoids and active and deactivate them opposite of each other, or use a DoubleSolenoid.
Unread 27-01-2014, 14:28
FRC #3236
thanks for the reply,
Our team is using a double solenoid would the code still be the same or would their be any minor changes?
Unread 27-01-2014, 14:42
Flywheel Police
DoubleSolenoid solenoid = new Solenoid(1, 2);
solenoid.set(DoubleSolenoid.Value.kForward);
kReverse would fire it the opposite direction.
Give that a try. You can also do something like:
Solenoid solenoid2 = new Solenoid(2);
solenoid2.set(false);
Unread 27-01-2014, 14:46
Domenic Rodriguez's Avatar
Domenic Rodriguez Domenic Rodriguez is offline
FRC #0316 (LuNaTeCs)
Domenic Rodriguez has a spectacular aura aboutDomenic Rodriguez has a spectacular aura aboutDomenic Rodriguez has a spectacular aura about
You would use the DoubleSolenoid class instead of the Solenoid class:
// Create a new DoubleSolenoid with the forward channel in port 1,
// and the reverse channel in port 2
DoubleSolenoid doubleSolenoid = new DoubleSolenoid(1, 2);
In addition, the call to DoubleSolenoid#set() is a bit different than Solenoid#set(). Instead of taking a boolean value, it takes a DoubleSolenoid.Value object:
// Set the solenoid to the 'forward' position
doubleSolenoid.set(DoubleSolenoid.Value.kForward);
// Set the solenoid to the 'reverse' position
doubleSolenoid.set(DoubleSolenoid.Value.kReverse);
// Set the solenoid to the 'off' position
doubleSolenoid.set(DoubleSolenoid.Value.kOff);
You can find more details in the FRC javadocs, located at "C:\Users\user\sunspotfrcsdk\doc\javadoc\index.html" on any computer that has the FRC Java plugins installed.
LuNaTeCs - Learning Under Nurturing Adults Teaching Engineering Concepts and Skills - Small and Mighty!
FRC 316 LuNaTeCs - Student (2011-2014), Lead Programmer (2011-2014), Team Captain (2013-2014), Operator (2013), Drive Coach (2014), Mentor (2015-????)
'11 Philly Regional Finalists, '13 Chestnut Hill Finalists, '13 Lenape Champions, '13 Archimedes Division, '14 Chestnut Hill Champions, '14 Lenape Champions
FTC 7071 EngiNerds - Founding Advisor (2013-2014) | FRC 5420 Velocity - Founding Advisor (2015)
Grove City College Class of '18, Electrical/Computer Engineering (B.S.E.E)
