Go to Post If it's the loss of American lives that concerns the nation, why not campaign aggressively against smoking, or improve automobile safety? At least then, the benefits will be tangible, and substantially more significant to the well being of the locals. - Tristan Lall [more]
Unread 26-01-2014, 18:48
Sh1ine Sh1ine is offline
FRC #2791
Sh1ine is on a distinguished road
Constant-force springs
Our team is thinking about using some constant-force springs for our shooter. We are curious if you can double the springs up on the same axle.
To clarify, we are wondering if it is possible to open two springs, place them on top of one another and then let them roll into one package. Has anyone ever done this? How does it work if you have? Can you double the force in almost the same space as one spring?
Thanks in advance.
Unread 26-01-2014, 18:49
geomapguy's Avatar
geomapguy geomapguy is offline
Centenary '18
AKA: Graham Maxwell
FRC #1818
geomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud of
Re: Constant-force springs
Vulcan Spring is actually giving FIRST teams a PDV
http://info.vulcanspring.com/first-robotics-competition
They even have a design guide http://www.vulcanspring.com/conforce...-force-springs
The Cowboys - FIRST Robotics Team #1818 2015-
The Bolton Bear Bots - FIRST Robotics Team #3666 2011-204 (30-26-0)
2014 Oklahoma Regional - 20/62 (6-4-0), 5/62 in OPR
2014 Arkansas Regional - 14/39 (8-7-0, Quarterfinalists with 1706 and 1939), 24/39 in OPR
2013 Lone Star Regional Dean's List Finalist!
2013 Lone Star Regional - 22/57 (6-5-0), 17/57 in OPR
2012 Bayou Regional - 16/49 (6-5-0)
2011 Dallas Regional - 10/52 (4-2-5, #6 Alliance Captain, Quarterfinalists with 2948 and 3350)
Unread 26-01-2014, 18:56
Dan.Tyler Dan.Tyler is offline
FRC #2449 (Out of Orbit)
Dan.Tyler has a spectacular aura aboutDan.Tyler has a spectacular aura about
The Vulcan spring PDV pamphlet included in the KOP has a couple of suggestions for using multiple springs.
I don't see why you couldn't wrap them together, but it would most certainly reduce their life and also their efficiency due to friction between the springs (i.e., you wouldn't double your force, you'd be at 180% or some amount of reduction like that)
Unread 26-01-2014, 20:10
Bryce Paputa's Avatar
Bryce Paputa Bryce Paputa is offline
FF TSL: Frog Farce
FRC #0503 (Frog Force)
Bryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond repute
I assume you are thinking of use 4 of the 40.9 pound springs? We called to ask them what the laminating procedure was, and they are supposed to be welded together. We decided that we couldn't do that safely and get a reliable product, so we are ordering pre-laminated ones form them for quite a bit more price and time than the stock ones. We don't have them yet to have any results.
Unread 26-01-2014, 20:18
pfreivald's Avatar
AKA: Patrick Freivald
We tried two 40-lb constant force springs from McMaster-Carr on a prototype shooter, and the exact same design (including the same pull) with surgical tubing threw the ball much, much farther.... I think there's a speed-of-wind-up and the sheer inertia of the things to take into consideration, there.
Also, trying to interweave them proved downright dangerous last year, so we had them on the same shaft, but side-by-side. Be very careful with these things!
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 26-01-2014, 22:15
Nathan Streeter's Avatar
FIRST Fan(atic)
FRC #1519 (Mechanical MAYHEM)
Thanks in advance.
1519's planning on using constant-force springs for our launcher... We used some (fiercely under-powered ones) on one of our intitial prototypes and just assembled the core of what we hope will be our competition launcher (also using constant force springs).
We're using 4 ~16lbf constant-force springs, with the potential to add smaller springs to tweak it (we already added two springs that we think are 7lbf). This gives us a total of 78lbf theoretically, which when we used our robot-weighing scale looked more like 65-72lbf. We have 8-10" of travel on this mechanism. Using human pull-back this seems to give a throw we're happy with (7+ vertical foot rise when fired straight up).
First, I'd be wary of springs that are on the order of 40lbf. We didn't inter-coil our 16lbf springs, but just pulling them back by hand to put them on a spool and bolt them to the launching mechanism was non-trivial enough that I frankly can't imagine doing it with much stronger springs (let alone 2.5x the strength!). I'm also unsure how inter-coiling springs or using larger springs affects the retracting speed... all I know is the little springs are quick enough for us.
Second, Vulcan Springs is providing a PDV for up to 6 springs. I didn't order them personally, but it sounded like it was easy to work with Vulcan Springs to get them. They were shipped promptly (next day?) and only took a few days to get to NH (I don't recall how many days). So, unless you really need the McMaster speed, I'd definitely recommend saving the $20+ per spring and use the PDV.
So far we like the constant force these springs provide!
Student: 2006-2010 (#1519)
Mentor: 2011-Present (#1519)
