Go to Post Haha, I applaud your efforts to read into the actions of the GDC, but I feel like trying to do so is like shooting at a target, in the dark, at a mile away, with a sawed off shotgun. - ttldomination [more]
Unread 26-01-2014, 09:39
johey johey is offline
FRC #4952
johey is an unknown quantity at this point
1/2 hex shaft coupling
We have been looking around and we can't find 1/2'' hex shaft coupling.
Does anyone know where we could find a coupling to fit two 1/2'' hex shaft together?
Thanks
Rookie team Carnicas 4952
Unread 26-01-2014, 09:50
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Re: 1/2 hex shaft coupling
You could get two of these and bolt them together.
Richard Wallace
since 2003
Unread 26-01-2014, 09:55
Tem1514 Mentor's Avatar
Tem1514 Mentor Tem1514 Mentor is offline
FRC #1514
Tem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to behold
You can always make one by drilling a hole in a piece of bar stock so that the HEX will fit in tightly then add set screws or even pin the Hex in place.
Of course a lathe will really help. The picture is taking a square block and making it round for all the poly cord pulleys we need on this years bot.
Unread 26-01-2014, 11:45
xForceDee's Avatar
xForceDee xForceDee is offline
AKA: Bart Kerfeld
FRC #4239 (Warpspeed)
xForceDee is a splendid one to beholdxForceDee is a splendid one to beholdxForceDee is a splendid one to beholdxForceDee is a splendid one to beholdxForceDee is a splendid one to beholdxForceDee is a splendid one to behold
How would you go about attaching the hubs to the shaft? Are you thinking tap a hole or two and use setscrews?
Unread 26-01-2014, 12:09
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Small Parts used to have things like this, but I can't find it anymore now that it's become Amazon Supply.
Unread 26-01-2014, 12:26
nixiebunny nixiebunny is offline
AKA: David Forbes
FRC #4183 (Bit Buckets)
nixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond repute
You might be able to find a piece of C channel that fits snugly on one side of the hex shaft. Cut two lengths of it, place them on either side of the butted shafts, drill holes through the channels and shaft as a sandwich, bolt it all together.
If you can't find the channel, then find a person with a brake and make some yourself. Use 60 degree bends.
--David Forbes
Mentor, Bit Buckets team 4183. Assistant cat herder and dispenser of legendary tales.
Need a Nixie watch? Yes, you do. Ask me.
Unread 26-01-2014, 12:28
Qbot2640's Avatar
Qbot2640 Qbot2640 is offline
AKA: Terry McHugh
FRC #2640 (Hotbotz)
Qbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond repute
How much torque / tension does it have to withstand? I've 3D printed hex "sleeve" that we plan to use as spacers - but it is incredibly strong - even when printed with a relatively low infill.
2012 Palmetto Regional Winners (Thanks 2059, 2815, and 287).
2012 Newton 14th Seed
2013 Chesapeake Regional Imagery Award Winners
2014 North Carolina Regional Imagery Award Winners
2014 Greater DC Regional Team Spirit Award Winners
2015 North Carolina Regional Finalists (Thanks 3971 and 587)
Unread 26-01-2014, 12:45
Michael Yeh Michael Yeh is offline
Lead Chief Delphi Lurker & CAD/Mech
FRC #4099
Michael Yeh is an unknown quantity at this point
http://www.vexrobotics.com/vexpro/ha...washers-g.html
They're available up to 2" long and super cheap, I've considered putting setscrews in them for couplings but never actually tried it.
It might not be strong enough for your application though.
Unread 26-01-2014, 16:03
BJT's Avatar
BJT BJT is offline
uh, should that be smoking?
AKA: Ben Thorsgard
FRC #0876 (Thunder Robotics)
BJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond repute
One of our students suggested we cut the end off a deep wall 1/2inch socket and put some set screws in it. Should work.
Unread 26-01-2014, 18:21
Bald & Bearded Bald & Bearded is offline
Jack of All Trades/Master on none
FRC #1885 (ILITE Robotics)
Bald & Bearded is on a distinguished road
Joehy:
If anyone near you has a 3D printer you can print one of these from
Thingiverse: http://www.thingiverse.com/thing:229161
Best to print with Nylon if they have an all metal hot end.
Unread 26-01-2014, 18:52
FRC #1514
Very good idea only problem is the socket has been heat treated and will be very hard to drill and tap unless you are using carbide tooling.
Unread 26-01-2014, 19:26
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Last year, we bought one of these: http://www.mcmaster.com/#2424k14/=qfauwg and ran a broach through it. I'm not entirely sure how well it will perform as a power transferring connection, but it connects two shafts just fine. Initially, we planned on running power through that coupling and then onto our climbing mechanism, but that never panned out, so instead, it just connected the two 'stub' shafts that our arm pivoted on.
In a pitch, I've also seen teams take a hex hub from AndyMark, drill two holes in it for set screws and use that to connect two shafts. Works just fine, but isn't 'pretty' fix unless you take the bolting surface off.
-Dustin Benedict
Unread 26-01-2014, 20:44
Quazar's Avatar
Quazar Quazar is offline
FRC #4765 (PWR UP)
Quazar is an unknown quantity at this point
We are using Hex-hole sleeves, purchased from SDP/SI; just search for part number "A 7C20-08".
The shafts we are joining are captive, and the sleeve is constrained between hubs, so we aren't bothering with set-screws, though it would be pretty easy to drill and tap for set screws if desired.
They are very solid and are a slip-fit on the VEXpro hex axles. They are not particularly cheap or light though. If you need them to be light, and you don't mind spending for a hex broach, you may be better off broaching round shaft couplers as thefro526 describes.
Cheers,
- Dean
Unread 26-01-2014, 21:53
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
You could use a lathe and drill the ends with a .251 drill and use a dowel pin and
and press it together or weld it
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
Unread 26-01-2014, 22:09
Aren_Hill's Avatar
Build Nifty Things
Here
217-3430
The WCP Colson Live hub has a 1.875" deep 1/2" HEX in it,
This and some pins may suffice.
-Aren
A guy who likes robots.
