Go to Post I remember seeing that hair do. It is what inspired me to become an MC one day. - Tetraman [more]
Unread 26-01-2014, 21:31
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
Re: More than one power distribution board
I think we managed to break one WAGO connector once.
To the OP: why would you want a second board? Have you run out of breaker slots or something?
Unread 26-01-2014, 21:34
MrBasse MrBasse is online now
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
Originally Posted by geomapguy View Post
Is there really a WAGO tool????
Yeah, here is one on amazon
Dang, there actually is one: WAGO
Looks like an insulated electricians screwdriver...
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 26-01-2014, 22:15
I remember having one with a white, cylindrical handle with WAGO printed on. We lost it a couple years ago.
Unread 26-01-2014, 22:23
tStano tStano is offline
AKA: Sparks
Team Role: Electrical
tStano will become famous soon enough
They must have come in the kit at some point. We have one exactly like that as well. I find it much much easier to use than a flathead screwdriver; prolly the angles on it.
Unread 26-01-2014, 22:32
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
Both of my teams lost ours during their rookie years...
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
Unread 26-01-2014, 22:34
The only thing specialized about the official Wago tool is the slippery coating that makes it a tiny bit easier to use than a standard small screwdriver. I typically use the kind that's often given away as a promotional item. (We're actually using a ground-down right-angle Allen wrench on our PDB this year because of a specific spacing issue in the robot.)
What does "intuitive" mean? Push the tool into the slot and the connector opens up. Pull it back out and the connector closes. I suppose you could break something if you got silly and tried to turn the handle while it was inserted, or if you tried to pry the plastic apart with it, but neither of those seem like an obvious thing to do.
Unread 26-01-2014, 22:59
SoftwareBug2.0's Avatar
AKA: Eric
FRC #1425 (Error Code Xero)
By intuitive I mean that if you tell someone to do it with no further instructions they are likely to do it the right way. If people just naturally did it right the warnings on page 9 of this document would not be needed.
http://www.usfirst.org/sites/default...tion_Board.pdf
Unread 27-01-2014, 04:10
zbrozek zbrozek is offline
None #1700
zbrozek will become famous soon enough
I'm not sure what the per-unit cost targets are, but I tend to use electronic overcurrent circuits. They've gotten remarkably capable and reasonably-priced in recent years. They're also amazingly compact.
I would also like to see an Ethernet switch integrated onto the power distribution board, with 12v and GND going to each pair of magnetic center taps. Then you could use a Ubiquiti Pico- or Nanostation and an Axis PoE-capable camera and get rid of a whole class of wires.
Unread 27-01-2014, 07:25
Have you seen something that can protect 40 amp wiring and still function at the 130 amp stall of a CIM for a short period of time?
Unread 27-01-2014, 07:32
Isaac501 Isaac501 is offline
FRC #0501 (The PowerKnights)
Rookie Year: 1995
Isaac501 is just really niceIsaac501 is just really niceIsaac501 is just really niceIsaac501 is just really nice
Originally Posted by SoftwareBug2.0 View Post
It requires a specialized tool to use and the intuitive way to use that tool is likely to break something.
Flathead screwdrivers aren't really specialized tools.
We use one small (3mm) for the PDB and a jewelers for the tiny ones for the cRIO and bumpers.
Insert tool, flex retaining clip, insert wire, remove tool. This hasn't broken our connectors or bumpers or boards in the 5 years we've been using it.
I don't think intuition is really a metric you should be caring about here - nothing we use is intuitive. Screwdrivers for some are not intuitive. Your iphone may be more intuitive for some of your students than a screw driver.
Team 501 Academic Advisor, Systems Build Mentor
Unread 27-01-2014, 07:36
Rookie Year: 1995
Like anything else in FIRST, using specialized hardware (the PDB) requires learning and mentoring. Since I lead the wiring team, I make sure to show the students the proper method before letting them hurt themselves (possible) or break our parts or tools.
"Just do it" is a recipe for broken hearts and broken hardware. It fosters creativity and learning, absolutely, but at the cost of safety and time/money/resources.
Unread 27-01-2014, 07:59
Everyone,
One of the biggest errors in terminating to the WAGO connectors is improper stripping of the insulation. WAGO recommends 5/8" to insure good contact inside the terminal. If you do that, and insert the wire so no copper is showing, then you have a good contact with the wire and it will not pull out. Please remember that these terminals are used in production environments and industrial installations. Installers rarely will insert the tool fully, they simply have learned the "feel" of inserting the tool, lifting while inserting the wire and then dropping the tool to lock the wire. While it takes two handed coordination, an experienced installer will take about 1 second for each termination.
Unread 27-01-2014, 09:40
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
What specifically do you think is wrong with the Wago connectors? I find them amazingly convenient, capable, and reliable.
They require a huge tool access space all around the sides. This is hard to package. If everything went up instead of out it would be fine.
Kettering Motorsports
Unread 27-01-2014, 10:31
They don't require much tool access at all if you use something compact, like a custom ground Allen wrench as was mentioned before. We use a small screwdriver with a 45 degree bend in it and we can place our board about an inch or so away from obstacles with no issue.
Andrew Basse
Unread 27-01-2014, 17:49
None #1700
Yup. Infineon makes excellent FETs, and Linear Technology makes excellent surge protection control ICs that drive them. BOM cost is a little high at about $8/channel in qty 1 from Digikey (so assume 1/10th that or less at any decent scale). They have capacitors to set the allowable overcurrent time. One of the circuits I built at work hard limits at 180A and is intended for 60A continuous. Consumes a little less than a square inch.
