Go to Post We also have a " big daddy" hand riveter. In my estimation one could have assembled the George Washington bridge with it. - DonRotolo [more]
Unread 24-01-2014, 16:35
Micah Chetrit's Avatar
Micah Chetrit Micah Chetrit is offline
FRC #3276 (NSR)
Micah Chetrit is on a distinguished road
Shifting with servos
Hello,
our team has never used a shifting gearbox on our robots before, and we are considering using an andymark 2774 to have a shifting system similar to how RI3D released their shooting mechanism. We don't plan on having pnumatics on our robot because the only place we would use them would be on the shifter, so we thought about using a servo to actuate it.
Can a servo handle it well? I doubt that the force required is as simple as the force required to move a lightweight dog gear since there are other forces acting on the gear, so I don't know how much resistance to expect. Are there any issues you foresee with using a servo to release a launching mechanism?
Unread 24-01-2014, 16:40
RonnieS's Avatar
RonnieS RonnieS is offline
Just a tad washed up
AKA: Ronnie Sherrer
FRC #0314
RonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond repute
Re: Shifting with servos
Originally Posted by Micah Chetrit View Post
Hello,
I don't have any math on hand to back this up but I will venture to say no. Remember, you might shoot a max of 10 times a match maybe more...might be able to just have storage with off board compressor..of course go by the rules but it shouldn't be ruled out (pneumatics that is)
"Do not argue with an idiot. He will drag you down to his level and beat you with experience"
Unread 24-01-2014, 17:35
Isaac501 Isaac501 is offline
FRC #0501 (The PowerKnights)
Rookie Year: 1995
Isaac501 is just really niceIsaac501 is just really niceIsaac501 is just really niceIsaac501 is just really nice
In my experience, servos are poor choices for shifting mechanisms on FRC robots.
I've observed them to have a difficult time shifting under load, and noted delays between left/right gearboxes when shifting.
Team 501 Academic Advisor, Systems Build Mentor
Unread 25-01-2014, 10:26
FRC #3276 (NSR)
Thanks for the input guys!
Unread 25-01-2014, 12:32
KamalRC's Avatar
KamalRC KamalRC is offline
Mechanical Lead 321
FRC #0321 (Robolancers)
KamalRC is an unknown quantity at this point
This video of Anymark's sonic shifter shows pneumatic and servo switching.
http://www.youtube.com/watch?v=cK3PqMj1TeM
Unread 25-01-2014, 14:34
Willyspu Willyspu is offline
AKA: Jim
FRC #2144 (Gators)
Willyspu is a jewel in the roughWillyspu is a jewel in the roughWillyspu is a jewel in the roughWillyspu is a jewel in the rough
Hello,
We haven't tested it yet, but we are looking at using one of these https://www.servocity.com/html/hs-805mg_servo.html
to move an arm that will pull & push the dog gear mechanism.
Jim
Unread 25-01-2014, 15:10
Jim
You sure that's within the servo spec for FRC? 4W, free speed*stall torque is the max.
With respect to the video, that's a non-loaded drivetrain, which will behave differently than a competition drivetrain, and there was at least once when the servo stopped in the middle of a shift. And the servo in general was slower than the cylinder. Both of those can easily be deal-breakers for a drivetrain servo shifter.
Unread 25-01-2014, 16:36
aciarniello's Avatar
aciarniello aciarniello is offline
AKA: Andy
FRC #4028 (The Beak Squad)
aciarniello has much to be proud ofaciarniello has much to be proud ofaciarniello has much to be proud ofaciarniello has much to be proud ofaciarniello has much to be proud ofaciarniello has much to be proud ofaciarniello has much to be proud ofaciarniello has much to be proud ofaciarniello has much to be proud ofaciarniello has much to be proud of
We are using an AM supershifter for our prototype winch mechanism. With a full load on our catapault, we could not get the dog to disengage even at 60 psi. I would be VERY doubtful that a servo could get it done.
Unread 26-01-2014, 16:13
AKA: Jim
FRC #2144 (Gators)
that begs the question . . . did you find a solution?
Unread 26-01-2014, 16:42
AKA: Jim
FRC #2144 (Gators)
Hmm, I guess 830mAx6v=4.98watts won't fly. Thanks!
Unread 26-01-2014, 19:06
FRC #3276 (NSR)
Interesting. thanks for the heads up. do you have a work around yet?
Unread 26-01-2014, 19:23
FRC #3276 (NSR)
Would this help? http://www.andymark.com/product-p/am-2584.htm
It has about twice the torque of a normal servo but only has 2 positions which apparently gives it more torque. Power drain isn't any more than other servos.
Unread 26-01-2014, 20:13
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Power = Voltage * Amps is one way to calculate power, but it is NOT the way the servo industry calculates it, and it is not the way FIRST calculates it. Please look at Eric's post that explains what the industry standard formula is. That servo is much much higher than 4.98 watts.
Unread 26-01-2014, 23:47
yash101 yash101 is offline
AKA: null
Actually, FIRST goes by the output power, not the input power.
Servos are a very bad choice because you will be shifting at top speeds. Servos have very little output torque, as compared to a piston. Also, designing the system with pneumatic pistons would be very easy!
You just need to have a pneumatic tank, valve, solenoid, all the basic components. You may be able to run off an external compressor, and precharge the cylinders!
Unread 27-01-2014, 17:03
FRC #1836 (MilkenKnights)
Some teams don't like using pneumatics because of the weight. If you are just running shifters than it may not be worth it.
67 has been one of these teams in the past. They have used the window motors instead of servos to successfully shift. You cannot shift on the fly, but it can also be lighter than a pneumatics system.
