Go to Post A challenge to those of you grumbling about the refereeing this year: Be a referee next year. - Alan Anderson [more]
Unread 27-01-2014, 03:32
gulce gulce is offline
FRC #4191
gulce is an unknown quantity at this point
Module not working
Hello all,
We have been trying to control our solenoid for pneumatic system from cRIO module 9472. However, there is no light on the module. We have tried a few troubleshooting processes that we could find on the web. Even we can't find solenoid entry on dashboard in test mode.
Any help is appreciated.
Unread 27-01-2014, 07:34
Re: Module not working
Gulce,
When you wire to the cRio solenoid module you have to supply power to the interface board. The module only provides closing contacts it does not provide the power to control the modules. There is a nice schematic on the side of the module that will explain this. You can choose 12 volts or 24 volts depending on the solenoids you are using. If you are using 24 volt solenoids, you can obtain that in parallel with the cRio power supply on the PD.
Unread 27-01-2014, 09:06
That suggests a problem with your program. Can you show us the code that involves the solenoid outputs you're trying to make work?
