Go to Post And to think, a lot of students are planning parties and celebrations on their last day of school and you guys are recycling trash. - JaneYoung [more]
Unread 21-01-2014, 10:56
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
Back Home in Indiana
FRC #4329 (Lutheran Roboteers)
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
4329's Drive Train
We received our painted frame and belly pan back last night and went about assembling our all gear drive (minus the gearboxes) -
Once we get our 3 CIM ball shifters in and get everything wired up I'll post a few more pictures.
The frame, wheels, gears & hardware are under 20 lbs. The frame is made from .090" 6061 T6 Aluminum. The center 3 wheels have a .100" drop from the outer wheels.
A big thanks to our sponsor Seyer Industries for making this possible. Also thanks to teams who have posted their inspirational all-gear driven designs in the past, I don't think we'll ever go back to chain or belts now.
Feel free to ask questions, thanks!
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
Unread 21-01-2014, 12:52
Thumbs up Re: 4329's Drive Train
So hexy <3
Unread 21-01-2014, 17:34
Answer42's Avatar
Answer42 Answer42 is offline
Answer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud of
Under 20 for full gear drive. That's spectacular.
My comments do not reflect the views of associated teams.
Unread 22-01-2014, 10:20
Without the gearboxes & CIM motors Once we get those the weight will easily double.
Unread 26-01-2014, 22:27
Tonight we got our 3 CIM ball shifters incorporated, the drive is mechanically complete awaiting controls and wiring:
Unread 27-01-2014, 08:15
ksc1073 ksc1073 is offline
AKA: Kate
FRC #1073 (The Force Team)
ksc1073 is an unknown quantity at this point
And I thought our direct driven mecanum with sonic shifters was cool...
This is the most gorgeous drivetrain I've ever seen.
Unread 27-01-2014, 08:44
Chadfrom308's Avatar
Chadfrom308 Chadfrom308 is offline
Slave to the bot
AKA: Chad Krause
FRC #0308 (The Monsters)
Team Role: Driver
Chadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to behold
I cant see the pictures because my school blocks them But, I did see that your chassis weighed 20 lbs with hardware. That is very light! Now I cant see it, so help me out here. Did you guys bend your 6061 aluminum? We had a couple things bent out (like a battery box, and a claw for 2011) and our battery box was really weak at the bends. In fact, one match, we got a hard hit and the box cracked and we had to replace it.
Our chassis is water jetted 5052 aluminum. We got this idea from team 67's 2012 tech notes (Which I recommend everyone reads). We bought the stock 5052 sheet and gave it to Chrysler for water jetting since they only have 6061 stock.
Anyways, our frame is 10lbs without any wheels or gearboxes. We are getting it powder coated and we will put them on. Our prototype shooter weighs more than the whole chassis!
Edit: I saw the chassis! It looks really nice! You sure use a lot of rivets! By the way, changing http:// to https:// in almost any link that is blocked will let you go to that site
Last edited by Chadfrom308 : 27-01-2014 at 08:52. Reason: Found a way to cheat the system!
Unread 27-01-2014, 09:57
Our sponsor did bend the 6061 T6 for us. We went with a larger bend radius hopefully to avoid cracking or fractures. This is our first year trying a sheet metal drive and our first year doing all-gear so I'm sure we'll learn a few things that we should or shouldn't have done for next year.
One other feature that I'm loving (so far) is that we don't have a flange on the bottom of the outside plate. This allows for very easy removal & insertion of our wheel assemblies. Our tube shafts are low enough in the frame that they act as support ribs. We're still considering adding additional standoff supports if needed once we start driving this with full weight.
Unread 27-01-2014, 10:28
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
Beautiful drivetrain! 1983 accidentally cut some 1/16th 6061 on the waterjet in the pre-season and decided to try it rather than scrap it. We found it bent quite well when we used a large radius tool, and didn't show any issues with cracking in the corners. I am surprised that your shop was set up to bend 6061, since most sheet metal places I've worked with heavily encourage 5052.
Regarding the flange, I suspect your shafts will be enough support considering you'll have bumpers on the chassis during competitions. The only scenario of concern would be a point load low on the side panel in between shafts, and that's going to be hard to do with a flat field and bumper-to-bumper contact.
Unread 27-01-2014, 10:29
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
We routinely bend 6061 in house as well, and just use larger bend radii to avoid cracking.
Mentor 2415
Unread 28-01-2014, 03:47
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
Evan,
6061 sheet stock comes in different tempers. T0 to T6. The T0 temper will bend easily. Heat treating after the bending process to get the part strong and stress free.
The T6 temper will crack if the radius is sharp. Another way to bend 6061 T6 is with a wrapper. The wrapper will make a large radius using sharp 1/32 inch dies.
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
Unread 04-02-2014, 10:50
We did a weight check tonight with everything we could think of that will be on the fully assembled robot. We may need to add weight
Unread 04-02-2014, 10:57
Woolly's Avatar
Woolly Woolly is offline
Programming Mentor
AKA: Dillon Woollums
FRC #1806 (S.W.A.T.)
Woolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond repute
30 pounds of LEDs?
Team 1806 Student: 2012-2013 | Mentor: 2013-Present
Unread 04-02-2014, 11:01
Justin Shelley's Avatar
Justin Shelley Justin Shelley is offline
FRC #3885 (Shockers)
Team Role: Driver
Justin Shelley is on a distinguished road
Send a message via MSN to Justin Shelley
Very impressive, look forward to seeing you in STL! Would you mind explaining how 10wd drive works? I would assume one of two ways.
1) Drop center and outer two are at same level
2) Wheels form an arc where the middle wheel is the lowest and the outer wheels are the highest.
extremely impressive either way
My comments or views do not necessarily reflect those of any affiliated organizations or teams
Unread 04-02-2014, 11:04
We went with the 3 middle wheels being dropped more than the outer wheels. I actually hadn't even heard of this wheel arcing until 703's thread came up again so we'll have to look at that for the off-season or next year.
Originally Posted by Woolly
30 pounds of LEDs?
Oh there will be LEDs
