Go to Post Seasons are often made or broken in the first week of build season. 1114 wouldn't be repeatedly giving their strategic design seminar if it wasn't that important. - Knufire [more]
Unread 22-01-2014, 15:12
cmwilson13's Avatar
cmwilson13 cmwilson13 is offline
AKA: Christopher Wilson
cmwilson13 has a spectacular aura aboutcmwilson13 has a spectacular aura aboutcmwilson13 has a spectacular aura about
Re: Puncher Shooter
we used it on our 2008 ball and its what we are using this year.
link from my old teams 2008 bot
http://www.youtube.com/watch?v=QeQSGmFnKAE
"Like the WWF, but for smart people." -George HW Bush
Team Member 1771 2008-2009
Team Mentor 1771 2010-2012 2014-2016
Team Mentor 4509 2013-2014
Team Mentor 3998 2013-2014
Unread 23-01-2014, 11:25
J.Warsoff's Avatar
Happy Birthday! J.Warsoff J.Warsoff is offline
BECAUSE SCIENCE
AKA: Jared Warsoff
FRC #1676 (The Pascack PI-oneers)
J.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond repute
Re: Puncher Shooter
Our team tested both a puncher and catapult design (when I was home for break). Last time I checked, I believe that we found the catapult was more accurate and consistent (Someone from my team correct me if I am wrong, as I haven't been at the shop since last Saturday.)
From what I can tell, a puncher has a smaller area of contact than the catapult during the actual shooting process. Since it is applying a lot of force to a small area, it causes much more deformation in the ball than the catapult, which can lead to inconsistency in the shooting (due to even the smallest factors like amount of air in the ball, location of point of contact, etc.) Once again, someone correct me if my observations are wrong.
"I reject your reality, and substitute my own!" -Adam Savage
Check me out on Twitter or Facebook
Acoustical Engineering & Music major at the University of Hartford / Hartt School of Music Class of 2017
Unread 23-01-2014, 11:52
Qbot2640's Avatar
Qbot2640 Qbot2640 is offline
AKA: Terry McHugh
FRC #2640 (Hotbotz)
Qbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond repute
Re: Puncher Shooter
I think our's fits into the description you are calling a "puncher," but we discovered that "punching" was not as effective as "pushing."*
http://youtu.be/UK2f9lvskcQ
This is three 3/4" cylinders with 12" stroke through some fairly high performance solenoids (.75 M^3/s flow) and the return ports left open to allow quick venting. We need to turn the pressure down to about 42 psi to avoid breaking things. (And we'll need to attach some kind of spring to bring the plunger back to the firing position.)
*The difference: we found it most effective to have the ball rest on the plunger of the cylinders before launch (push) rather than have a separation and have the ball struck by an already moving plunger (punch).
2012 Palmetto Regional Winners (Thanks 2059, 2815, and 287).
2012 Newton 14th Seed
2013 Chesapeake Regional Imagery Award Winners
2014 North Carolina Regional Imagery Award Winners
2014 Greater DC Regional Team Spirit Award Winners
2015 North Carolina Regional Finalists (Thanks 3971 and 587)
Unread 27-01-2014, 10:08
nuclearnerd's Avatar
nuclearnerd nuclearnerd is offline
Speaking for myself, not my team
AKA: Brendan Simons
FRC #5406 (Celt-X)
nuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant future
Re: Puncher Shooter
I'm not sure if this is a "puncher", but we were able to get an air cylinder to push the ball for a ~15 ft shot during our "proof-of-concept" stage. It took more work than you're expecting though:
1) You need a big cylinder. We used a 2" bore, 15" stroke
2) You can't deliver enough power through the FRC legal solenoid valves. Instead, treat the cylinder like a gas spring and pre-charge it.
3) Because you can't exhaust air through the solenoid valves fast enough either, you can't use the same cylinder to retract. Instead, you need a separate cylinder (or winch), and a release mechanism (basically all of the things you would need if you were working with surgical tube instead of a cylinder)
4) The cylinder should have a tank of at least equal volume attached directly to the port with hard pipe (preferably 1/4") *not* tubing. The extra volume of the tank will keep the pressure in the cylinder from dropping to nothing when it expands, but the flow restriction through the port puts an upper limit on power.
So in summary - doable, not much easier than a surgical tube slingshot, although it does let you vary force.
Check out this thread from a few years ago: http://www.chiefdelphi.com/forums/sh...ad.php?t=79952
Unread 04-02-2014, 00:43
AKA: Brendan Simons
FRC #5406 (Celt-X)
Re: Puncher Shooter
Aw hell, I just re-read the manual after seeing a couple of successful pneumatic catapult. I thought the solenoid valve restriction was 1/8" orifice diameter (another way to limit CV). Turns out it's 1/8" NPT Port Diameter. You can get solenoid valves with 1/8 npt ports and CV's above 1.0 each - more than enough!
/that moment when you realize you've made a wrong assumption, and its too late to change course
Unread 04-02-2014, 02:17
Happy Birthday! RRLedford RRLedford is offline
FTC 3507 Robo Theosis -- FRC 3135
AKA: Dick Ledford
FRC #3135 (Robotic Colonels)
RRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond repute
Re: Puncher Shooter
Surgical tubing puncher with pneumatic retraction:
http://www.chiefdelphi.com/forums/sh...highlight=rail
It is all about hitting a good peak ram velocity while it remains in contact with the ball. Having pneumatics pre-pressurized and surgical tubing prestretched with ram in retracted position is important. Rapid acceleration is what is needed, so a low mass ram with high initial force is best,
-Dick Ledford
FTC 3507 RoboTheosis
FRC 3135 Robotic Colonels
Unread 08-02-2014, 14:55
Trey178's Avatar
Trey178 Trey178 is offline
M.C. in Training
AKA: Trevor
FRC #0178 (2nd Law Enforcers)
Trey178 is an unknown quantity at this point
Re: Puncher Shooter
My advice to you and the rest of your team is never have your face anywhere near this beast when pulled back. I still get flashbacks to 2006 when we tested a similar method for launching foam basketballs.
Unread 08-02-2014, 17:02
Jibri Wright's Avatar
Jibri Wright Jibri Wright is offline
FRC #1781 (Electric Eagles)
Team Role: CAD
Jibri Wright will become famous soon enough
Re: Puncher Shooter
I don't mean to call you out, but I don't think 2006 had basketballs. I believe the balls were foam though.
You know someone likes something when after doing it a million times, they still marvel at it as if it was the FIRST.
Greatness asks how can I make it better. Genius asks how can I make it different.
Unread 08-02-2014, 17:37
orangemoore orangemoore is offline
AKA: Roger Moore
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
Re: Puncher Shooter
It it is a little scary standing next to it while it is loaded. Luckily we don't have to do that during the competition.
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
