Go to Post Hallry's back! Tell a Friend! - Tyler Olds [more]
Unread 25-01-2014, 14:44
faulknna faulknna is offline
FRC #0435
faulknna is an unknown quantity at this point
Detecting If We're Competing
Does anyone know of a way to detect if we're at competition? I'm trying to implement a battery-saving mechanism on the driver station that will beep at you (kind of like an alarm clock) after 3 seconds of being below 11 volts, and will disable the robot after 13 seconds; however, I need to make sure the robot doesn't get shut down in the middle of a match. While a simple solution might be to have a control on the dash board, I'd rather have something that can't be so easily flipped.
Unread 25-01-2014, 15:13
Re: Detecting If We're Competing
Java and C++ have a method in the DriverStation class called isFMSAttached.
You may want to experiment with your thresholds once you have the robot built.
Unread 25-01-2014, 15:38
JohnGilb JohnGilb is offline
Programming Mentor, Drive Mentor
FRC #0488
JohnGilb has a spectacular aura aboutJohnGilb has a spectacular aura aboutJohnGilb has a spectacular aura about
One small addendum - I would be very, very careful with any code that disables your robot. A bug, misconfiguration, or regression in that could could have the undesirable side effect of disabling your robot at competition.
Unread 26-01-2014, 08:52
I wasn't sure what language. It doesn't look like LV exposes that in a palette VI, but it is easy to get from one of the lower level VIs not in the palette.
But before doing this, does the robot use that much more power when enabled than when disabled? Is it the compressor? Because it may be simpler to have a toggle for energy saving that is more explicit. Binding this to being on a field could happen later, but it will in fact be hard to test before you are at an event.
Greg McKaskle
Unread 26-01-2014, 09:38
magnets's Avatar
magnets magnets is offline
IIRC, isFMSAttached didn't work last year.
Unread 27-01-2014, 00:09
yash101 yash101 is offline
AKA: null
Just have a checkbox, with it's value saved. That way, whenever you go to comps, you just need to press the comp checkbutton once and you're set. It's not too hard either!
Unread 27-01-2014, 00:28
What about the practice field?
Unread 27-01-2014, 11:01
sircedric4's Avatar
sircedric4 sircedric4 is offline
AKA: Darren
no team (The SS Prometheus)
sircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond repute
TL;DR: Set a flag in your autonomous routine, only triggered when you are playing a real game or during "practice" on driver station.
We are going to be doing something different on the real field then at our pits with one of presets on the robot we are building and I had a similar problem.
I will tell you how I plan to only allow a preset when we are in the pits versus during the actual game and you can see if it applies for you.
Basically, we use IterativeRobot in Java and C++ and we are setting a flag during the autonomous portion. While that flag is tripped, then we are in a real game and as such I do not want to return to our start position of the robot. When it is not tripped, that means we just flipped the driver station to teleop and are playing around in the pit and I will allow the robot to be returned to start position automatically then.
Unread 27-01-2014, 11:16
chris.boyle's Avatar
chris.boyle chris.boyle is offline
Programming Mentor
FRC #0068 (Truck Town Thunder)
chris.boyle is on a distinguished road
I have asked this question in the past and the answers I received are in the following thread. http://www.chiefdelphi.com/forums/sh...d.php?t=114614
Also, I've attached a photo of how we are using the information.
2014 Chairman's Award--Michigan State Championship
2014 Chairman's Award--Waterford District
2014 Winner--Great Lakes Bay District
2013 Chairman's Award--Kettering District
2012 Championship Division Finalists--Thanks 330 and 639
Unread 27-01-2014, 11:48
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
We have a similar situation where we want to automatically up the data rate of telemetry data from the robot to the driver's station when not on a competition field. If the cRIO can keep up, we're talking roughly 2Mbits on top of video & normal FMS traffic, so we really want to scale it back on the field.
Can anyone confirm that the FMS Attachment bit still works? Does it detect the actual FMS & FMS Lite?
GitHub
Unread 27-01-2014, 17:27
magnets's Avatar
After looking at our code from last year, the FMS method did not work during the match we tried it at.
Unread 27-01-2014, 19:39
bs7280 bs7280 is offline
FRC #3734
bs7280 has a spectacular aura aboutbs7280 has a spectacular aura aboutbs7280 has a spectacular aura about
Make it so that no matter what the battery level is, the power can not be cut until at least 2 and a half minutes have passed (I would do three just to be safe), then once 2.5 minutes have passed, the program can cut off power after 11 volts
Unread 27-01-2014, 20:33
matthewdenny's Avatar
matthewdenny matthewdenny is offline
FRC #6054 (Dukes)
matthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant future
The solutions proposed so far are elegant and seem effective. However I suggest 1 more possible option. You could have a simple switch wired to a digital input. The default position (as well as the switch unplugged position) would be competition settings and the other option could be for testing.
Unread 28-01-2014, 07:40
I believe that the bit in the protocol is set, but I can't really verify that the bit makes it to the control byte unmodified. Anytime the FMS Present message and blue strip shows on the DS, that will trigger the FMS bit. So this should work with FMS lite.
Greg McKaskle
