Go to Post how can anyone Not Notice An entierly Pink Team? - Tytus Gerrish [more]
Unread 26-01-2014, 11:55
mrwright's Avatar
mrwright mrwright is offline
Coach
AKA: Michael Wright
FRC #4522 (Team SCREAM)
mrwright is a splendid one to beholdmrwright is a splendid one to beholdmrwright is a splendid one to beholdmrwright is a splendid one to beholdmrwright is a splendid one to beholdmrwright is a splendid one to beholdmrwright is a splendid one to behold
Team SCREAM's prototype robot
After three long hard weeks Team SCREAM finally has a working practice bot. We are now ready to assemble our competition robot.
http://youtu.be/QTlVUHw5ECU
Unread 26-01-2014, 11:59
Re: Team SCREAM's prototype robot
Very nice.
Have fun with practice!
Unread 26-01-2014, 22:55
zinthorne's Avatar
zinthorne zinthorne is offline
AKA: Avery
FRC #5827 (Code Purple)
zinthorne will become famous soon enough
Nice! just a quick question, do you have problems with the ball falling out when you are driving? I noticed you had the white plastic sheets to keep it in, but is that enough?
Unread 26-01-2014, 22:59
bs7280 bs7280 is offline
FRC #3734
bs7280 has a spectacular aura aboutbs7280 has a spectacular aura aboutbs7280 has a spectacular aura about
what are the specs of your shooter?
Unread 27-01-2014, 01:09
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Very impressive. This robot looks like it has the potential to be very, very successful at competitions. I have only one change to suggest.
Lose the meccanums.
-Plutarch
Unread 27-01-2014, 01:43
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Bold added for emphasis. Seeing as this is one of the first complete robots (systems working together) to be posted except for the 72 hour builds, I would say you are doing just fine. That looks really great, and your field setup is really impressive. I wish we had that much space.
Unread 27-01-2014, 02:06
Keegbot's Avatar
Keegbot Keegbot is offline
AKA: Keegan McCrary
FRC #2438 (Beta Blues)
Keegbot is an unknown quantity at this point
I noticed your robot had to pause and re-adjust where the ball was before it could shoot in the end. Do you see teams taking advantage of this and playing physical defense on you while you set up. This could be a problem, especially with the mecanum where they could easily push you around.
Unread 27-01-2014, 08:56
mrwright's Avatar
Coach
AKA: Michael Wright
Thanks for the feedback and questions. We will do a more thorough reveal soon that shows all of the subsystems.
We are looking forward to having LOTS of driver practice with this robot. We have really discussed the pros and cons of the mecanum setup and we knew going into this we would have to give our drivers plenty of time to practice with it. Our drive base is also configured so that if we decided to we could easily swap them out for traction wheels.
In terms of the shields we are using 1/4" poly carbonate sheets to hold the ball in place. It actually works really well. We put a slight fold on the bottom so that it angles inwards to pinch the ball in place. It also has enough flex to let it fly out when we shoot. We have hit it pretty hard on all sides and the ball has been held tight.
Our shooter setup is a spring loaded catapult with a winch. The winch has an air cylinder to engage the window motor to pull it down. The only problem we have had with the winch is that it takes about 5 seconds to fully reset the catapult. We are testing out different pulley diameters to optimize the speed.
Finally, on the last shot our operator had to readjust the ball because he didn't get it fully seated on the catapult with the collector arm. Ideally he will have this set in place before stopping aiming for the shot. These should be alleviated with driver practice. With our mecanum setup we will not be coming to a complete stop when shooting. Our trajectory on the ball gives us a lot of room for hitting the sweet spot.
If you have any more questions or comments please let us know. We will post more details soon...
Unread 27-01-2014, 09:20
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
I would love to see a video of the robot being hit "pretty hard" and seeing the ball stay in place. A slight pinch with those polycarbonate sheets is a pretty darn good idea IMO.
Also, are you worried about teams hitting your collector while you're shooting? If I were playing defense on you that's what I would do to turn your robot away from the goal.
Unread 27-01-2014, 09:51
mrwright's Avatar
Coach
AKA: Michael Wright
Yes. We are worried about it. We understand the risk of the exposed arms and we will be bringing extras for sure in case of damage but it is a valid concern for us.
Unread 27-01-2014, 10:37
kdhir kdhir is offline
FRC #0246 (Overclocked)
kdhir is an unknown quantity at this point
Wow, that looks awsome!
I have a couple questions:
- Are you guys using just one cim per wheel or a cim and a mini-cim per wheel?
- Do you like the Vex Pro 6in mecanum? I heard that when strafing the rollers lock up some times?
Good Luck with the rest of build season, Looking great so far!
Unread 27-01-2014, 11:14
mrwright's Avatar
Coach
AKA: Michael Wright
We are using the toughbox nano from Andy Mark and have one cim per wheel.
So far we are really liking the VEX mecanums. I haven't really noticed them sticking when strafing yet.
Unread 27-01-2014, 11:17
1493kd's Avatar
1493kd 1493kd is offline
kd
FRC #1493 (FALCONS)
1493kd will become famous soon enough
Very impressive, are you able to pass by just reversing the intake? And what cylinders are you using to lower and drop it?
Unread 27-01-2014, 11:21
nlknauss's Avatar
nlknauss nlknauss is offline
STechnologyEM Teacher, Alumni
AKA: Nate Knauss
FRC #2729 (LC Storm Robotics Team)
nlknauss has a reputation beyond reputenlknauss has a reputation beyond reputenlknauss has a reputation beyond reputenlknauss has a reputation beyond reputenlknauss has a reputation beyond reputenlknauss has a reputation beyond reputenlknauss has a reputation beyond reputenlknauss has a reputation beyond reputenlknauss has a reputation beyond reputenlknauss has a reputation beyond reputenlknauss has a reputation beyond repute
Awesome work! Enjoy the driver practice and detailing time you have a head of you.
Nate
Nate Knauss
FRC 2729 Teacher-Drive Coach 2009-?, FTC 4390, FTC 7433
FRC 87 Student 2000-2002 and Mentor 2003-2006, FRC 1647 Mentor 2006-2008, FIRST Senior Mentor 2009-2013
"We can't change the cards we are dealt, just how we play the hand." -Randy Pausch
Unread 27-01-2014, 11:38
mrwright's Avatar
Coach
AKA: Michael Wright
We have a couple of passing options. We can throw it over the truss for a long pass or we can reverse our pulley on the catapult to adjust the throwing angle for shorter passes as well. For a short pass or hand off we can reverse the wheels on the collector to release the ball.
We are using 6" stroke cylinders with a 3/4" bore.
