ROBOREALM
Okay - I have roborealm downloaded but I do not understand how to make it work for this years competition. I am using the Axis IP camera and am programming in Java commandbase.
How do I make the image show up in the driver station? Do I still have to write code for it and how do I do that? How does it work? I need a lot of help with this because I do not understand anything about it. I looked at the tutorials and they did not help me at all. ANY help will be GREATLY appreciated. THANKS! |
Re: ROBOREALM
Follow the steps here to set up the camera: http://wpilib.screenstepslive.com/s/...onent-overview Once the camera is set up you should see the stream. No code required. There is a button on the driver station that you may have to press to activate the stream. Let me know once you have that up and running, and I can help you with referencing the camera via java. |
Re: ROBOREALM
We are interested in this topic as well, and have the camera set up. Would you please continue on to the part with java and roborealm?
Re: ROBOREALM
I've also figured out how to "include" another project with your robot code, which will allows me to provide bug fixes and updates as I work on the code more. Right now the library is only designed to answer the hot or not question. Due to performance issues with image processing on the crio, I am trying to keep the code as simple as possible. As I proceed through the season I may expand it as other features are requested. As far a roborealm goes, I am trying to avoid it for now. I would prefer leaving the network open for robot coms and not take up any of the bandwidth for image processing. |
Re: ROBOREALM
A good place to start for learning RoboRealm would be the 2013 FRC RoboRealm page: http://www.roborealm.com/FRC2013/. They have tutorials on how to set up and use RoboRealm, as well as how to send data to the robot with NetworkTables.
Edit: they also have a page for this year: http://www.roborealm.com/FRC2014/ Last edited by Domenic Rodriguez : 29-01-2014 at 16:54. Reason: Added an additional link |
Re: ROBOREALM
Here's some more documentation that might help for using RoboRealm with Java:
http://wpilib.screenstepslive.com/s/...with-roborealm Hope this helps |
#7
Re: ROBOREALM
Okay - Thanks!
