Go to Post Just be nice. It works better in the long run. - Libby K [more]
Unread 24-01-2014, 22:35
Merfoo's Avatar
Merfoo Merfoo is offline
FRC #0955 (CV Robotics)
Merfoo is an unknown quantity at this point
Talk to rpi from crio
Hello, so we're using opencv python on the raspberry pi this year for vision process and we're wondering how we get/send data like booleans, doubles, ints, strings to the pi from the crio in java. I've seen posts talking about i2c and udp but they dont talk how to do it/show code examples. Are there any examples to help us get started?
Unread 25-01-2014, 00:04
daniel_dsouza daniel_dsouza is offline
does what needs to be done.
FRC #2449 (Out of Orbit Robotics)
daniel_dsouza has a spectacular aura aboutdaniel_dsouza has a spectacular aura about
Re: Talk to rpi from crio
i am working on pretty much the same idea. I don't have any code yet, as my past week has been spent dealing with team administration issues, but if you don't have something by the time I have finished mine, I would be happy to share what I will write with you!
Unread 25-01-2014, 00:28
bijan311 bijan311 is offline
FRC #1714
bijan311 is an unknown quantity at this point
I'm not sure how much this will help you because it is written in C++ and not java, but my team has successfully created a camera tracking program on the raspberry pi that sends the data to the CRio via udp packets. The code can be found here (the code used on the raspberry pi is in the raspberry pi folder and the rest is robot code).
To send the integer values to the CRio, we just used a some if statements to convert them to strings, and when receiving the data we converted them back into integers.
I hope this helps. If you have any more questions I will try to respond to them as soon as possible.
Unread 27-01-2014, 11:34
amreuland's Avatar
amreuland amreuland is offline
Overworked Insomniac
AKA: Austin
FRC #2583 (Westwood Robotics)
amreuland is on a distinguished road
Since you are using python, you can use a NetTables implementation.
I found that Team 3574's try at it is pretty good.
https://github.com/Team3574/2013Visi...c/nt_client.py
To set values in python:
from nt_client import NetworkTableClient
nt = NetworkTableClient("Team Number")
nt.setValue("key name", data) # Data can be number, string, boolean
To get values in python:
value = nt.getValue("key name")
To get the value in java:
import edu.wpi.first.wpilibj.networktables.NetworkTable;
NetworkTable table = NetworkTable.getTable("Table Name");
table.putNumber("key name", double);
table.putBoolean("key name", boolean);
table.putString("key name", String);
To set values:
double number = table.getNumber("key name");
boolean bool = table.getBoolean("key name");
String str = table.getString("key name");
Unread 27-01-2014, 12:45
gluxon's Avatar
gluxon gluxon is offline
\n
AKA: Brandon Cheng
FRC #0178 (The 2nd Law Enforcers)
gluxon has a spectacular aura aboutgluxon has a spectacular aura aboutgluxon has a spectacular aura about
My question is, Why would you need to? For most vision processing configurations, the Raspberry Pi would talk directly with the camera, then send data to the cRIO one-way.
If you must go the other way, I would recommend the NetworkTables as well. Otherwise, a simple udp server and client should do it for C++.
Unread 27-01-2014, 14:59
gixxy's Avatar
gixxy gixxy is offline
Programming and Arduino Mentor
AKA: Gustave Michel III
FRC #3946 (Tiger Robotics)
gixxy is on a distinguished road
Last year Team 3946 used a network Socket Connection to talk between the crio and rpi.
Basically we had a Socket Server running in Python on the RPI and a Socket Client in Java on the cRIO.
Here is the code we used:
Python Side:
PyGoalFinder
Java Side:
This is the code that actually ran the socket in a separate thread and parsed the data.
ThreadedPi.java
This is the Subsystem we used to Interface the system:
ThreadedberryPi.java
Programmer - A creature known for converting Caffeine into Code.
Studying Computer Science @ Louisiana Tech University
Associate Consultant @ Fenway Group
2012-13: 3946 - Head of Programming, Electrical and Web
2014 - 3468 - Programming Mentor
2015 - Present - Lurker
Unread 29-01-2014, 00:41
Merfoo's Avatar
So if I want to use the NetworkTable "tableData" in python using https://github.com/Team3574/2013Visi...c/nt_client.py it would be
client = NetworkTable("tableData")
and in java it would be
NetworkTable table = NetworkTable.getTable("tableData");
Unread 29-01-2014, 01:16
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
I would recommend using pynetworktables. It's a cross-platform python wrapper (so everything in NetworkTables is implemented) around the official WPILib implementation of NetworkTables, and has sample code that comes with it.
Github site: https://github.com/robotpy/pynetworktables
Samples: https://github.com/robotpy/pynetwork...master/samples
Windows binaries: http://firstforge.wpi.edu/sf/frs/do/...ktables.2014_1
Unread 29-01-2014, 13:05
sparkytwd's Avatar
sparkytwd sparkytwd is offline
FRC #3574
sparkytwd will become famous soon enough
For python it would be
client = NetworkTableClient("955")
You can run nt_client.py from the command line like so:
python nt_client.py 955 and it will set some test values for you.
