Re: [FTC]: Functioning LEDs?
Please note that, although an official forum posting would clarify this for sure, I don't believe that options 2 and 3 are legal, at least this year. I believe all functional LEDs must be powered by the prototype board.
Yes, getting a offical saying on this would be the best. But Looking at the manual again just now, we found this.
So yes, it seems like this year, the Option 2 and 3 I listed would be "out of code," for this year. |
As I understand it - you can power LEDs from the battery and control them from the prototype board.
See post #59 here: http://ftcforum.usfirst.org/showthre...r-Thread/page6 |
On our robot, we soldered a special circuit board that the Prototype board plugs into, and we have some MOSFETs and other circuitry on it, to control lights, and other functional sensors. Power is coming from the main robot battery. The LEDs we used were RGB led strips, non-addressable, and we use them to display our alliance color during a match.
We have functioning LEDs this year. A writeup of how we accomplished this is here:
http://degreesplato.wordpress.com/20...s-need-lights/ The lights will pulse teal (our team color before and after the match, purely decorative). During the match they indicate the direction the drivetrain is pointing (it's reversible). The NXT is also keeping a match timer and they will start flashing yellow at the beginning of the end game and flashing red with 10 seconds left. I thought the timer might be inaccurate, but it's surprisingly correct. There's various stuff we do in autonomous, mostly for debugging as well. |
THANK YOU SO MUCH! I've been wanting to do this for some time, but never figured out how to do it. Is there a wiring diagram/parts list?
#7
After the season is over I'll see about teaching our electronics lead how to use Eagle and put up a schematic.
Parts are simply an ATmega328 burned with an Arduino bootloader, the Hitechnic Protoboard, an addressable LED strip (available from Adafruit or Sparkfun), a 5v voltage regulation circuit built around a LM7805 with heatsink, a couple of small breadboards, and miscellaneous hookup wire. |
