Go to Post "It's not a bug, it's an unlisted feature." - Barry Craig [more]
Unread 26-01-2014, 22:49
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
theawesome1730 will become famous soon enough
Re: 1/2 hex shaft coupling
I would recommend investing in a hex broach in both 3/8 and 1/2 inch sizes. You will not believe how much they will get used. We needed similar couplings last year and could not find any so we made them by broaching 1/2 inch round shaft couplings
2015 GKC Engineering Inspiration
2015 Colorado Winners
Unread 26-01-2014, 23:27
AllenGregoryIV's Avatar
AllenGregoryIV AllenGregoryIV is online now
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
We are using these this year, from Team 221 systems. They seem to be working out alright.
http://www.team221.com/viewproduct.php?id=137
The problem with buying a hex broach is you have to buy an arbor press big enough to use it. I know we don't have the space for that until next year when we get our new shop.
Unread 27-01-2014, 13:12
Quazar's Avatar
Quazar Quazar is offline
FRC #4765 (PWR UP)
Quazar is an unknown quantity at this point
Originally Posted by Aren_Hill View Post
Here
217-3430
The WCP Colson Live hub has a 1.875" deep 1/2" HEX in it,
This and some pins may suffice.
Nice find! This would be easier to drill and tap than the steel sleeves I posted. They wouldn't work for us this year because we need something that can fit inside a 1⅛" diameter bore, but I will definitely keep this in mind for future years.
Cheers,
- Dean
Unread 27-01-2014, 14:26
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
I prefer not to use set screws, generally. The only ones I've had decent luck with are the ones with knurled points to help prevent backing out.
If I were connecting two shafts together I would use a few spring pins, dowel pins, or cotter pins. Also consider axial shaft retainers. A little fancier, but they can work quite well.
Unread 27-01-2014, 14:55
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Buy a 1/2 inch deep well socket and cut the square end off.
Easy and cheap.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 27-01-2014, 15:26
Engineering Coach
Easy and cheap.
Well why didn't I think of that last year. Good suggestion.
Unread 27-01-2014, 17:52
Imaginary Friend
AKA: Kevin Li
Team Role: Student
Thanks but I think BJT actually beat me to it.
Kevin Li
596 - Sciclones
