Go to Post What really matters is what you got out of the FIRST season, and how you can use it to build on what you know. - Adam Richards [more]
Unread 08-01-2002, 21:02
Smeg-asurus Smeg-asurus is offline
#0367 (Godfather)
Smeg-asurus is an unknown quantity at this point
Send a message via AIM to Smeg-asurus
Question How many Motors are allowed???
Can a robot have more of one type of motor than is supplied in the kit?
Or is the number of each particular type of motor limited by how many are allready supplied?
NEED AN ANSWER ASAP
and thank you to cheif delphi for hosting this forum
Smeg it! Mickey Mouse it!Mechanism!
In theory it will work.
It's all about practicalability.
No Mike, you must take the nut off before you can put the washer on.
-Common team phrases
Unread 08-01-2002, 22:22
kiracofe8 kiracofe8 is offline
#1317 (Digital Fusion)
kiracofe8 will become famous soon enough
The rule in the past has always been that as far as motors go, what you see in the kit is what you get. No additional motors are allowed.
/* Daniel */
Unread 08-01-2002, 22:29
#0367 (Godfather)
Thank you for your imput, but as many rules have been lightened up on this year, my team wants to be sure on this.
Especially during the early days of design, we want to be sure, as the specific answer to this will greatly effect how we design our machine.
Anyone else's opinions on this matter, would be appreciated. Please make reference of which specific rule you refer to.
Unread 08-01-2002, 23:27
AdamT's Avatar
AdamT AdamT is offline
#0401
AdamT is on a distinguished road
I had the impression the rule was only the motors provided. This has always made the competition fair to those teams without the funds to go and buy more motors. If you want to be 100% sure, you should post a question on the yahoo groups message board created by FIRST.
The site is: http://yahoo.groups.com/group/FRCtech2002
Unread 09-01-2002, 07:06
Gadget470's Avatar
Gadget470 Gadget470 is offline
A Fire Outside
AKA: Brandon Joerges
no team (Alpha Omega)
Gadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the rough
Send a message via ICQ to Gadget470 Send a message via AIM to Gadget470
Link Correction
You got your link a bit back words, not yahoo.groups, groups.yahoo
http://groups.yahoo.com/group/FRCtech2002/
Unread 09-01-2002, 08:59
#0367 (Godfather)
My arguement to the rules is still the fact that i cannot find a rule that specifically limits the number of one kind of motor to the amout supplied.
Does anyone see a rule I may have skipped over?
I did submit my question to the yahoo group but i believe that will take quite a bit of time for a reply.
Unread 09-01-2002, 11:03
ErikJusten ErikJusten is offline
#0677 (A Few Screws Loose)
ErikJusten is an unknown quantity at this point
In the "Robot" section of the rules, Rule 1.1.1 clearly states:
"There are three sources of materials:
1) parts found in the Kit of parts
2) Parts from the Additional Hardware List
3) Parts from Small Parts"
Motors certainly aren't on the additional Hardware list, and they aren't in small parts. I believe that "parts found in kit of parts" means if it isn't in the box, then you can't use it - that is, you can't go out and buy more of something, even if it's in the kit, since the bought part wasn't found in the kit of parts. Further on in the same rule it says that "any material used in the robot must come from the above sources and no other." This I think backs up my claim that an extra drill motor wouldn't be allowed since it wouldn't come from the kit of parts, but rather from something else.
I'm pretty sure (I'll have to check when I get home) that the rule was always like this, but no one ever really questioned the english........ And it was always judged that you can't go and use 4 drill motors if only given 3.
Unread 09-01-2002, 19:35
gthakore gthakore is offline
#0843 (WOSS Wyverns)
gthakore is an unknown quantity at this point
reply about motors
you can have 8 motors according to your circut board
gthakore
Unread 09-01-2002, 22:27
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
All motors provided and not more
You can clearly have more than 8 motors.
My understanding is that you can use all the motors that are in the kit:
3 Bosch Drill (in fact a Johnson Electric motor)
2 Chiaphua
2 Fisher Price (in fact a Mabuchi motor)
1 Mabuchi
2 Globes
1 Johnson Electric
2 Keyang
2 Jideco
1 "Torque Motor"
Total 16
If you think about it, there are even more motors in the kit but you can't use them to get shaft work out of them (the fans, the pump, the beacon light motor, etc.)
Joe J.
Unread 09-01-2002, 23:51
motors
I meant that you can only have a maximum of 8 motors connected to the circut board. the rest are just extras for selection
gthakore
gthakore
Unread 10-01-2002, 06:31
Adrian Wong Adrian Wong is offline
#0596 (SciClones)
Adrian Wong is an unknown quantity at this point
Send a message via AIM to Adrian Wong
There are 14 PWM outputs and 8 relay outputs. You can use as many Speed Controllers and Spikes as you want as long as they power the motors. It would be very difficult to exhaust all those connections.
I believe it is possible to connect all the motors in the kit, supposing you had enough speed controllers, to the Robot Controller. Each could be delegated its own PWM or relay connection, allowing for individual control of each motor.
In short, you can have more than eight.
Unread 10-01-2002, 17:23
Joseph F Joseph F is offline
#0506 (Steel Friars)
Joseph F is an unknown quantity at this point
Send a message via AIM to Joseph F
i think the 8 motor limit statement was due to the fact that you only get 8 30AMP breakers and all motors must be connected to a 30A breaker.
Unread 10-01-2002, 17:28
#0596 (SciClones)
Oh. In that case, you can still have more than eight motors since snap-action circuit breakers are on the Additional Parts List.
How Many drill motors are we allowed to use. archiver 2001 2 23-06-2002 23:32
Suppose you want seat motors... archiver 2000 0 23-06-2002 22:50
