Re: 375 Key Hub
Are you trying to right click and Save As? Then drag and drop into your program.
Re: 375 Key Hub
I've tried that, and it doesn't work.
Re: 375 Key Hub
Email AM, seems the file just isn't there.
Re: 375 Key Hub
I have thanks, just wanted to see if anyone happened to have the file laying around so I didn't have to wait until tomorrow.
Re: 375 Key Hub
Aloha!
From the looks of it, you are trying to down load the step file for the (AM-134a) 375 Key Hub.. I agree the links are both broken.. Have you tried the (AM-0134) Key Hub? http://www.andymark.com/product-p/am-0134.htm The CAD file works fine and the general specs listed are the same. Though it does not show the height.. Could work in a pinch.. just extrude a bit if needed... ![]() Good Luck! |
Re: 375 Key Hub
Thanks so much! I had not tried that.
#7
Re: 375 Key Hub
Given it is a fairly simple part I tried to download the PDF file and model the part. Unfortunately there is an issue with that file as well.
I did find a PDF this one, but it does not appear to be the 134a version. http://www.robotshop.com/andymark-375-key-hub.html |
