Go to Post I'm not the only one confused. Perfect. - MikLast [more]
Unread 27-01-2014, 23:36
Volunteer, WPILib Contributor
no team (Waiting for 2021)
pic: Diamond Wheels after 10 minutes
Unread 27-01-2014, 23:37
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Re: pic: Diamond Wheels after 10 minutes
Wow, that's concerning.
Were you running them on carpet?
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 27-01-2014, 23:41
Yeah that was on carpet. It was the carpet in the school, which is pretty similar to the competition carpet.
Team 4488 - Mentor 2013-2016
Unread 27-01-2014, 23:49
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
How much does your current robot weigh? What gear ratio?
A light drivetrain will tend to 'burn out' the wheels on carpet when starting from a stand still or changing direction. This is not so much the case when it's weighed down with mechanisms and bumpers. If you are using a low gear ratio (by which I mean: slow top speed) and lots of power (you mentioned 3 CIM gearboxes) the effect is more noticeable... I suspect that slipping the wheels on carpet would give the accelerated wear you're seeing.
BurkeHalderman's Avatar
BurkeHalderman BurkeHalderman is offline
Casual Robot Observer
BurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant future
Can you describe your drivetrain setup? what kind of weight were you testing with? This is pretty concerning, we just ordered a few sets and were hoping they would be better than the original Versawheels we used last year, which wore to almost nothing after 10 matches.
[2010-2014]: FRC 3266 Robots-R-Us: Founder and Alumni
2010 (5-5-1): Buckeye Regional; Driver
2011 (4-5-0): Buckeye Regional; CORI; CAGE Match; Drivetrain/Manipulator Operator
2012 (7-13-0): Buckeye Regional; Queen City Regional; CAGE Match; BPRC; Drivetrain Operator
2013 (25-15-1): Queen City Regional; Buckeye Regional; Crossroads Regional; CORI; Ohio State Champs; CAGE Match; BPRC; Drivetrain Operator
2014 (21-10-0): Crossroads Regional; Queen City Regional; Designer; Mechanical/Design Mentor
Founding an FRC team as an 8th grader sure wasn't easy, but it was totally worth it.
Get in touch with me:
Personal Facebook
I believe every human has a finite number of heartbeats. I don’t intend to waste any of mine. – Neil Armstrong
Unread 27-01-2014, 23:56
Its a 6WD WCD, but currently only the center wheel is driven. Its geared to about 10.5 FPS, and weighs 75 lbs. We did notice it was slipping, only if we went full forward and full back, which we didnt do too often.
Unread 27-01-2014, 23:59
Aren_Hill's Avatar
Build Nifty Things
I can respond with "that's not a lot"
Even after the nubs are gone there is still a significant amount of tread before you hit plastic.
We had 973 run them at an offseason competition and practice and estimate around 2 regionals of use out of a set including some practice.
These were designed to be a more consistent grip level for the entire life of the wheel and last longer than the other 4" VersaWheels with W tread (depending how often you spin your wheels).
They aren't meant to last forever though, as we still wanted a decent level of grip.
-Aren
A guy who likes robots.
Unread 28-01-2014, 01:03
AdamHeard's Avatar
Lead Mentor
-Aren
Yeah, we were very happy with them.
Unread 28-01-2014, 08:56
JamesCH95's Avatar
JamesCH95 JamesCH95 is online now
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Wait wait wait... you're using a 6-cim 2WD setup, geared relatively low, on a very light robot?
You're hilariously inside the 'traction limited' operational regime and I would wager a large sum of money that you're spinning wheels WAY more than you think you are.
See this drivetrain chart: http://team358.org/files/mechanical/...nRefTables.jpg
You're robot is 50% of the weight of a fully-loaded FRC robot (in round numbers), and thus has less than 50% of the assumed weight (148lbs) on its driven wheels. With a 4-cim drive you're well within the 'safe' i.e. 'traction limited' case. With 6 cims you're just begging to spin and roast wheels.
Unread 28-01-2014, 09:32
nuttle nuttle is offline
AKA: Allen Nuttle
FRC #4080
nuttle has much to be proud ofnuttle has much to be proud ofnuttle has much to be proud ofnuttle has much to be proud ofnuttle has much to be proud ofnuttle has much to be proud ofnuttle has much to be proud ofnuttle has much to be proud of
This is probably also a factor, half the weight is on non-driven wheels. You should address this before you do much more driving.
Unread 28-01-2014, 13:21
Yeah we plan on chaining the rest up when we get actually get the sprockets. Maybe it was spinning more then I thought they were. I guess I'm just used to the AM wheels, were you can spin them for days and they don't wear much at all. Nobody on our team has every used anything but the AM kit wheels, whether it was the old or new style.
