Go to Post I am all for high school sports, but as Dean continually preaches, we sometimes are not putting enough emphases in the right places. - Bill Beatty [more]
Unread 28-01-2014, 11:27
akash992391 akash992391 is offline
AKA: Akash
FRC #4684
akash992391 is on a distinguished road
Help with Pneumatics.
Hello guys, this is our first time using pneumatics. Right now we are stuck on the compressor. Can anyone show us the wiring/labVIEW programming for the compressor? We are using a Double Solenoid and we have 1 pneumatic cylinder. All we want is to control the cylinder to shoot forward/reverse.
Unread 28-01-2014, 11:34
Re: Help with Pneumatics.
Are you familiar with the examples that are built in to the LabVIEW environment? You'll find them under the Support tab on the Getting Started screen. The Compressor With Cylinder example should give you what you need.
Unread 28-01-2014, 11:48
Ben Martin's Avatar
Ben Martin Ben Martin is offline
Long Distance Mentor
FRC #0225 (TechFire)
Ben Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond repute
team358.org has a great whitepaper on how FRC pneumatic systems work, including the LabVIEW code you asked for.
TechFire 225 -- Website -- Facebook
2015 & 2016 MAR Champions
Past teams: 234, 1747
Unread 28-01-2014, 15:01
AKA: Akash
FRC #4684
Is the compressor supposed to turn on as soon as the robot is turned on?
Unread 28-01-2014, 15:02
Not until the robot is Enabled at the Driver Station.
Unread 28-01-2014, 15:57
Qbot2640's Avatar
Qbot2640 Qbot2640 is offline
AKA: Terry McHugh
FRC #2640 (Hotbotz)
Qbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond repute
Also - the compressor will come on when the stored air side pressure drops below the point set to turn it on. If you run the robot, and it ends fully charged with air, then it is probable that the compressor will not come on the next time you run until you use some of the air. (Unless there is a leak, of course.)
2012 Palmetto Regional Winners (Thanks 2059, 2815, and 287).
2012 Newton 14th Seed
2013 Chesapeake Regional Imagery Award Winners
2014 North Carolina Regional Imagery Award Winners
2014 Greater DC Regional Team Spirit Award Winners
2015 North Carolina Regional Finalists (Thanks 3971 and 587)
Unread 28-01-2014, 18:04
AKA: Akash
FRC #4684
Unhappy Re: Help with Pneumatics.
Oh thank you so much guys. Really big help. Our compressor is working properly now. The next problem/step is controlling the Double Solenoid(Electric Valve Festo). We've tried programming it and when we pull the trigger on the joystick, the light turns on, but only on one side of the Double Solenoid. Also, how would you program it to switch where the air comes out of. So we can make the Cylinder/Pneumatic go forward and retract, with the pull of the trigger.
Unread 28-01-2014, 19:37
Did you look at the LabVIEW example? It shows exactly how to program a double solenoid so you can extend a cylinder with one signal and retract it with another. If you want to extend it while the trigger is pressed and retract it while the trigger is released, you can use the trigger through a NOT function to control the retract.
Unread 28-01-2014, 20:17
AKA: Akash
FRC #4684
We have the compressor and the solenoid set up exactly how the example wants us to. But when we deploy the example code, on FRC driver station- the robot code won't turn green. How do you deploy the example? "Compression with cylinder"
Unread 28-01-2014, 22:50
The examples don't get deployed. You set the IP address of the RT CompactRIO Target (right-click it and choose Properties, then change the 10.0.0.2 in the General section to match your team number), then you just Run the example vi. It connects to the cRIO and sends the necessary code over, maintaining the connection so you can use the vi's front panel.
