Go to Post but if you can build stuff, you can figure out how to build other stuff. - GeeTwo [more]
Unread 28-01-2014, 15:02
Re: Help with Pneumatics.
Not until the robot is Enabled at the Driver Station.
Unread 28-01-2014, 15:57
Qbot2640's Avatar
Qbot2640 Qbot2640 is offline
AKA: Terry McHugh
FRC #2640 (Hotbotz)
Qbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond repute
Originally Posted by akash992391 View Post
Is the compressor supposed to turn on as soon as the robot is turned on?
Also - the compressor will come on when the stored air side pressure drops below the point set to turn it on. If you run the robot, and it ends fully charged with air, then it is probable that the compressor will not come on the next time you run until you use some of the air. (Unless there is a leak, of course.)
2012 Palmetto Regional Winners (Thanks 2059, 2815, and 287).
2012 Newton 14th Seed
2013 Chesapeake Regional Imagery Award Winners
2014 North Carolina Regional Imagery Award Winners
2014 Greater DC Regional Team Spirit Award Winners
2015 North Carolina Regional Finalists (Thanks 3971 and 587)
Unread 28-01-2014, 18:04
akash992391 akash992391 is offline
AKA: Akash
FRC #4684
akash992391 is on a distinguished road
Unhappy Re: Help with Pneumatics.
Oh thank you so much guys. Really big help. Our compressor is working properly now. The next problem/step is controlling the Double Solenoid(Electric Valve Festo). We've tried programming it and when we pull the trigger on the joystick, the light turns on, but only on one side of the Double Solenoid. Also, how would you program it to switch where the air comes out of. So we can make the Cylinder/Pneumatic go forward and retract, with the pull of the trigger.
Unread 28-01-2014, 19:37
Did you look at the LabVIEW example? It shows exactly how to program a double solenoid so you can extend a cylinder with one signal and retract it with another. If you want to extend it while the trigger is pressed and retract it while the trigger is released, you can use the trigger through a NOT function to control the retract.
Unread 28-01-2014, 20:17
AKA: Akash
FRC #4684
We have the compressor and the solenoid set up exactly how the example wants us to. But when we deploy the example code, on FRC driver station- the robot code won't turn green. How do you deploy the example? "Compression with cylinder"
Unread 28-01-2014, 22:50
The examples don't get deployed. You set the IP address of the RT CompactRIO Target (right-click it and choose Properties, then change the 10.0.0.2 in the General section to match your team number), then you just Run the example vi. It connects to the cRIO and sends the necessary code over, maintaining the connection so you can use the vi's front panel.
