Go to Post If you don't like physical play build a stronger robot. - Koko Ed [more]
Go Back   Chief Delphi > Technical > CAD > SolidWorks
Unread 28-01-2014, 16:22
BA SW's Avatar
BA SW BA SW is offline
BA SW is an unknown quantity at this point
Re: SolidWorks Tip: Projectile Motion of Ball
"Projectile motion", as in "no air drag, just gravity"?
Yes, the simulation does not account for drag. However, it would be easy to add drag. Additional forces can be added in the simulation and then by running the same simulation you would get results with the drag included. I just did not put that in the video.
There are also flow simulations in SolidWorks if you are concerned with aerodynamics and drag.
