Thread Tools |
Rating:
Display Modes |
Re: How Does one Program (and also wire) a Denso Window Motor?
We don't usually have clips for them either--we typically solder spade terminals onto the metal tabs to make our connections. As for the controllers, it depends on what you want to do with them. If your application only relies on the motor spinning at full speed in a certain direction, then you should use SPIKE relays. If you need speed control, use Victors, Jaguars, or Talons.
