Go to Post Learning from the innovations of others is part of what makes FRC great, regardless of your own teams accomplishments or lack thereof. - hg273 [more]
Unread 28-01-2014, 17:19
LOHS3868 LOHS3868 is offline
FRC #3868
LOHS3868 is an unknown quantity at this point
How Does one Program (and also wire) a Denso Window Motor?
We've got these denso window motors that we don't have plugs to ( ). It seems like a lot of people don't. Anyways, I'm looking for a way to wire those into the power board. I'm also wondering: How are these programmed? Should I use a 'SPIKE motor controller' to control whether or not it's spinning one way or the other?
Any help is much appreciated. Thanks!
Unread 28-01-2014, 17:22
aryker's Avatar
aryker aryker is offline
FRC #0868 (TechHOUNDS)
aryker will become famous soon enougharyker will become famous soon enough
Re: How Does one Program (and also wire) a Denso Window Motor?
We don't usually have clips for them either--we typically solder spade terminals onto the metal tabs to make our connections. As for the controllers, it depends on what you want to do with them. If your application only relies on the motor spinning at full speed in a certain direction, then you should use SPIKE relays. If you need speed control, use Victors, Jaguars, or Talons.
Unread 28-01-2014, 17:25
FRC #3868
Oh man, that's so simple! I can't believe it didn't even cross my mind. For some reason I thought these motors would be an entirely different beast to tame. Thank you so much!
As for the wiring I think we can handle that. Does it matter which side of the motor we put the + and - ends of the wire into?
Unread 28-01-2014, 17:30
Qbot2640's Avatar
Qbot2640 Qbot2640 is offline
AKA: Terry McHugh
FRC #2640 (Hotbotz)
Qbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond repute
Keep in mind, one of the nice things about these motors is that they spin relatively slow, so it is easy to use them without the need for speed control - through a Spike. And you can switch their direction via programming when wired this way.
2012 Palmetto Regional Winners (Thanks 2059, 2815, and 287).
2012 Newton 14th Seed
2013 Chesapeake Regional Imagery Award Winners
2014 North Carolina Regional Imagery Award Winners
2014 Greater DC Regional Team Spirit Award Winners
2015 North Carolina Regional Finalists (Thanks 3971 and 587)
Unread 28-01-2014, 17:49
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
We use female terminals that fit over the male terminals in the connector. Then we fill the entire connector with quick-set epoxy (hot glue works in a pinch).
Unread 28-01-2014, 17:54
I'll tell you who does: anyone who got them through FIRSTChoice. http://www.firstchoicebyandymark.com/en/fc14-181
