Go to Post Finally, they're getting rid of the spotlights. I'm sick of seeing ridiculous inside jokes up there. - Karthik [more]
Unread 10-01-2002, 17:09
chrisw chrisw is offline
chrisw is an unknown quantity at this point
Send a message via AIM to chrisw
problems with receiving signals between radios (need help0
hi we are having trouble with the radios, rs-422 (radio that goes on the robot). we get standby on the radio (robot)
and flashing no data/radio. can anybody help us?
~ chris ~
Unread 10-01-2002, 17:46
s_alaniz s_alaniz is offline
#0057 (Leopards)
s_alaniz is an unknown quantity at this point
Radio trouble shooting
Cris,
I assume you have power hooked up to both the robot interface and the operator interface.
Do you have your team number properly set on both the operator interface and the robot interface? If they don't match you will get that error.
We have that same error after the units initially worked... we have a bad robot side radio unit... yep it can happen, plus it's flacky. a bump causes it to turn in and off. we had to switch to last years unit until we can get a replacement.
Hope this helps
Best Wishes
Steve
"What good is technology if you can't abuse it?" - Ted Forth
Unread 11-01-2002, 09:12
Matt Leese Matt Leese is offline
Been-In-FIRST-Too-Long
FRC #1438 (The Aztechs)
Matt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond repute
Send a message via AIM to Matt Leese
First of all, make sure everything is plugged in (both ends of cable; one to RC and one to radio; as well as another cable with one to the OI and one to the other radio). Also, make sure that you have the right radio on each end (in my experience they still work if you switch which one is on which end but do it any way just to make sure). Also make sure that the OI is plugged in and turned on. Also, try to connect via Tether to see if the problem is in the radios (or cables) or in something else (RC, OI, etc.).
Matt
Unread 11-01-2002, 09:59
Kit Gerhart's Avatar
Mentor, coach, whatever--
FRC #0233 ("The Pink Team")
Check your cables
A few days ago we had a communications problem with our '01 robot which turned out to be the cable between the radio and the receive box on the robot. Such problems are rare, but they sometimes occur.
Team 1062, The Storm, 2003
Unread 11-01-2002, 10:35
Last but not least, the radio modem is a 900 MHz device so nearby cell phone towers and cell phones can confuse the beastie. This of course assumes that all the above are satisfied. (Power, connector, good cable, etc.)
