Go to Post In FIRST you have the right to remain silent, anything you say can and will be held against you and your associates in the court of public opinion. - Koko Ed [more]
Unread 28-01-2014, 21:10
Re: RoboRealm to Labview help
I'm not familiar with the communication mechanism you are using. I also don't have enough context to know which diagrams are running where. But I'd assume that if you are using RoboRealm, the diagrams are on the cRIO. But you are opening a .2 IP. Does that make sense?
I thought that RoboRealm also implemented Network Tables. That means you should be able to use the LV implementation of Network Tables.
Greg McKaskle
