Re: FRC Player Station Rules
For clarification I mean an external desktop monitor that can be plugged into the classmate as the screen on the classmate is very small and low resolution
I have seen teams use external USB monitors on driver stations before, you may want to consider these as they are much lighter.
You could just use a higher res laptop with a bigger screen. There isn't rule that prohibits you from using a different PC than the Classmate. Anyway, you'd need to install LabVIEW+Update Suite if you're using LabVIEW for your robot+dashboard, or else, if programming with Java or C/C++, just install the Update Suite and the respective IDE to get the Driver Station and the special "Smart Dashboard".
Keep in mind that external monitors typically require their own power supply.
As per section 2.2.8 of the game manual: Quote:
It's possible, but you'll probably want to run some tests to make sure you don't trip the breaker at the competition. |
Thats for the help you solved my problem
