Go to Post I think these new rules are making the message coming from FIRST perfectly clear - engineering is about what happens between your ears, not what comes out of your deep pockets. - KenWittlief [more]
Unread 28-01-2014, 20:38
Qormix Qormix is offline
Programming Captain
AKA: Marc Levesque
FRC #4976 (Rebel Robotics)
Qormix is an unknown quantity at this point
FRC Player Station Rules
Hi My Name is Marc Levesque. I'm one of rockie team 4976 programmers. I cannon't seem to find anything in the FRC Manual about an external monitor.
Unread 28-01-2014, 20:47
Connerd's Avatar
Connerd Connerd is offline
09R - JBD Detachment, USU ROTC
AKA: Conner Doggett
FRC #3166 (First Year Ravens)
Connerd will become famous soon enough
Re: FRC Player Station Rules
By external monitor do you mean:
1. A monitor you plug into your driver station, for some reason, or
2. A desktop computer to act as your driver station?
I don't know why you would want to plug another monitor into your driver station, as that would block you view of the Real World Monitor, and I don't know the rules on 2., but I don't think you'd want to have to lug around a full desktop computer. Just use a classmate, netbook, small laptop, etc. as your driver station.
Remember, your driver has the best monitors in his/her head. Good luck, and I hope I answered your question.
*EDIT* Just out of curiosity, if the above wasn't what you wanted to use an external monitor for, what did you want to use it for?
2012-2014 - Team 3245 Ravens, Student/Mascot
2014-20?? - Team 3245 Ravens, Alumni
2015-20?? - Team 3166 Ravens, Mentor
Unread 28-01-2014, 21:56
Programming Captain
AKA: Marc Levesque
For clarification I mean an external desktop monitor that can be plugged into the classmate as the screen on the classmate is very small and low resolution
Unread 28-01-2014, 22:16
nathannfm's Avatar
nathannfm nathannfm is offline
AKA: Nathan
FRC #3940
nathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant future
I have seen teams use external USB monitors on driver stations before, you may want to consider these as they are much lighter.
[2016-20??]: Mentor: FRC Team 3940"CyberTooth"
[2013-2016]: Mentor: FRC Team 365 "MOE"
[2012-2013]: Mentor: FRC Team 3929 "Atomic Dragons"
[2011-2012]: Mentor: FRC Team 365 "MOE"
[2008-2011]: Student: FRC Team 365 "MOE"
[2007-2008]: Student: FTC Team 365 "MOE"
[2005-2007]: Student: FLL Team "The MOEstangs"
Unread 28-01-2014, 22:19
lucas.alvarez96's Avatar
lucas.alvarez96 lucas.alvarez96 is offline
AKA: Lucas Alvarez
FRC #2576 (Chilean Heart)
lucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to all
You could just use a higher res laptop with a bigger screen. There isn't rule that prohibits you from using a different PC than the Classmate. Anyway, you'd need to install LabVIEW+Update Suite if you're using LabVIEW for your robot+dashboard, or else, if programming with Java or C/C++, just install the Update Suite and the respective IDE to get the Driver Station and the special "Smart Dashboard".
Unread 28-01-2014, 23:00
Bryan Herbst's Avatar
Bryan Herbst Bryan Herbst is offline
AKA: Bryan
FRC #2052 (KnightKrawler)
Bryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond repute
Keep in mind that external monitors typically require their own power supply.
As per section 2.2.8 of the game manual:
Each PLAYER STATION also includes a single 120VAC NEMA 5-15R power outlet. It is located on the right side of each PLAYER STATION shelf. This outlet is protected by a 3-Amp circuit breaker and can be used to power the OPERATOR CONSOLE.
So you will need a power strip, and you'll need a monitor that doesn't draw much current. The monitor I'm using now draws 1.2A, and I believe the classmate draws 1.2A. You could of course also just charge your laptop before you get to the field.
It's possible, but you'll probably want to run some tests to make sure you don't trip the breaker at the competition.
Team 2052- KnightKrawler
Mentor and volunteer
Unread 28-01-2014, 23:24
Programming Captain
AKA: Marc Levesque
Thats for the help you solved my problem
